  • Replies 75
by the looks of it Jake you may need to roll the guards a bit to get +16 wheels under!
dave
i don`t think + 16 have a chance on the front ....all though +18 +20..seems to be number for 260te37
and 250/260
ill try my wheels tomorrow...might end up having a set of lm gt2 for sale ..ex justin fox
Hey Sydneykid,
Just looking at your front bar, looks very different to mine. What year and spec is your Staj??
Ken
Hi Ken, the build date was February 1997 and it's a base model, no woodgrain, no sunroof/s, no sat nav or TV. I picked this one because of the front bumper and headlight design and the blue colour.
It needs shocks real bad and it was owned by a smoker (not usual for Japan) so it reaks. But nothing that 2 days with the steam cleaner won't fix. A couple of days geting the scratches polished and/or touched up and the LHS rear (white door) painted, then it will be ready for rego. Add 1 tow bar and away we go. :cool:
Hahaha, the foot brake still freaks me out when I use it !!
This weekend I'll be able to confirm if R34 GTT mags fit and clear everthing, I'll grab some pics as well just so you can see how/if the fill the gaurds etc..
SK - (a bit off topic), how did your fabricator go with making up a tow bar ? I'd be keen to buy one if it doesn't cost an arm and a leg.
J
well +16 offset stick out too far ...unless i buy some overfenders.(flares).ie:
http://www.freeway-dolphin.co.jp/photo_g/ito/005st.jpg
then i`m making the car fit the wheels ...doesn`t seem right really ...allthough i like look of the small flares ..finishes off the body kit..:confused:
plan b: DAVE send me some details on 18 x9 +20 you can get please ... rays prefered thx
J
The Stagea is still in the panel shop and I haven't had a chance to get the tow bar measured up. We had a hectic few weeks of racing, one car dropped a diff, it was on the way out, no loss. Another copped a severe over rev (14,000 rpm +) due to a missed shift and another blew a head gasket (no, I didn't assemble that engine). Thankfully the other 2 ran like clockwork all weekend. :wassup:
I you want, I will ask how much to make 2 both at the same time. I can then send it down or you can pop up and get it fitted. Anyone else want a 2.2 tonne capable tow bar? Maybe a group buy chance here. :(
Jeff at C-RED knows what fits and what dosent, I am looking at putting 19 inch Budnik's on http://www.budnik.com/techInfo.asp you can find the way to work out the exact wheel size you can use for any brand on any car.
Wheels are from http://www.ziggyshotrods.com in NSW, 19 inch BILLET'S.
I you want, I will ask how much to make 2 both at the same time.  I can then send it down or you can pop up and get it fitted.  Anyone else want a 2.2 tonne capable tow bar?  Maybe a group buy chance here. :D
Sounds good. 2.2 tonne is a damn big one !! I was looking at something around the 1.5 max, but I suppose it won't matter ;) I'd be interested in what sort of $$$ he can do one for fitted and also unfitted. Funds are slowly running out after buying the car ;)
Thanks
J
There seems to be 2 specs of tow bars these days, one around 1.2 tonnes for box trailers, bike trailers, tinnies and the like. Then there is the big one around 2.2 tonnes for car trailers, caravans and big boats. More info next week inc prices when I get a chance to get ours registered.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
