Use a 25neo head. Far better head.
Depending on the  power  and reliability  you are after will depend on  what work you have to do with it.
I just built  one 25 30 neo reliable  550rwhp on pump  fuel.
Everything  in the  engine is rated for 1200+hp so i know  i will never need to  upgrade anything for more hp.
Cost 20g.
https://www.sau.com.au/forums/topic/466202-rb-2530-build/#findComment-7765170
Have you read the RB30 PDF in the RB30 section of Forced Induction?
You can do a cheap job for up to 500hp or you can go all the way like Dave above - depends what you want and how much money you can spend.
https://www.sau.com.au/forums/topic/466202-rb-2530-build/#findComment-7765392
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
