Hi as title suggests I'm using an RB20 ecu to run my 25 drift sled and the vct doesnt seem to be working. Can not hear the solenoid click at all, have tried jacking the car up and had the wheels moving and still doesn't seem to work.
As far as i can work out the tuner has tried to use the air con signal pin in the ecu to try and trigger the vct. From the looks of it it seems to be done right, I'm starting to wonder if this is a software problem and he hasn't flashed the ecu to now know to use the air con...? He said he didn't know if it was working or not but didn't have time to check as we had other dramas that day with the car..
can anyone confirm that this is how you do it?
thanks
https://www.sau.com.au/forums/topic/466328-nistune-vct-wont-work/
i haven't got the software myself that's what i needed the tuner to do but i was trying to work out if it was a mechanical problem or a programming thing. Tbh he didnt seem to care if it worked or not which is annoying as that's one of the things i needed him to do..
yeh i don't think the vss is needed in my case as I'm trying to trigger it with the a/c as rb20 ecu doesnt have vct option at all. The other option in Nistune's manual is to use the fuel pump idle up pin as apparently the ecu adjusts the standard fuel pump but when you upgrade to better pumps this is no longer needed. This sounds a lot harder, messier though.
 I just wanted to see if how hes modified the board is correct as there's no diagrams on Nistune's site.  I'm pretty sure he just hasn't uploaded the files that let the ecu know that your now using the a/c so the solenoids not getting any signal atm....
Perhaps he hasn't flashed it with the correct firmware.. you have 2x options either trigger it from the green LED output OR use the AC trigger out.
You really need the Nistune software, consult cable to work this out.
Where are you located? I have a tuner license... will diagnose/fix for slabs of 150 Lashes
If the feature pack firmware is not installed you will need the ECU reflashed.  This is not the same as just using Nistune software to alter the tune, etc.  This is using the Nistune programmer.  Not all workshops that tune Nistune are "dealers" that can also program the boards.  You will need to ask your prospective tuners whether they are capable.  Any one of them should be able to tell you whether the feature pack firmware is installed though.  Nistune helpfully tells you if it is as you connect.
I was saying to use Nistune to see if he has the correct firmware.. and if he does, is it actually setup correctly.
Matt from Nistune will flash them for free, just pay for postage back.
Matt from Nistune will do a lot more than that.  He has performed deep surgery in my ECU on a couple of occasions to help me get the air-con working post Neo transplant.  Turns out that along with all the (simple) wiring problems of trying to use R34 ECU to work with R32 climate controller, my ECU was borked.  Had dud circuitry.  Matt spent a lot of time and just happened to have spares of the rather esoteric devices needed to repair it!
In one of the older software versions, there was an issue where the VTC attributes in the address file were crossed up, effectivly making the logic impossible to activate it (unless you knew the issue was there, and could swap the values accordingly). I had this issue personally.
Can't recall if it was ECU specific (type 2 Z32), it was the rpm engage/disengage fields that were ass about.
rb20 ecu cannot run vct. since rb20s never had it. it needs to be run off a trigger from either a boost controller with an aux output or a switch.
only way to get it to work as per normal would have been by using a z32 ecu instead of rb20.
This is no longer true.  Nistune's new feature pack firmware has changed this.  Which IS EXACTLY WHAT WE SAID ABOVE!
No, you're wrong.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
