 You will need a timing light to start with.  I prefer the ones that take batteries.....no induced signal from the car battery that way.  But I use mine on lots of different vehicles including motorbikes, so others will have other opinions on that.  Plus the R33's have the battery in the boot so.....hard to use one that doesn't have its own power anyway.
Most youtube clips show the ones that hook up to your cars battery.
Car has to be warm and idling at 650 rpm, every mark is 5 degrees, you need to be at the 4th mark [three gaps] for RB25, 5th mark for GTR, [check the sticker on your bonnet, should have the degrees you need], loosen the three bolts holding the CAS and turn this to adjust the timing - only loosen as much as you need, it shouldn't be flopping.  Turn off car, tighten bolts on CAS, start car and check. Kick back and have a beer!!!
Long version............google or youtube.
https://www.sau.com.au/forums/topic/466604-checking-timing/#findComment-7772447
And if you have an aftermarket ECU enable the timing lock so the timing does fluctuate at all trying to control the idle, etc.
I prefer to always hit the timing lock then hold the revs about 3000rpm then adjust the CAS, however if you have a stock ECU just ignore what I said and follow the instructions from Nissan.
https://www.sau.com.au/forums/topic/466604-checking-timing/#findComment-7773557
On ‎4‎/‎09‎/‎2016 at 9:55 PM, Hadouken said:
Sorry but there are 2 terminals at the fuse box under the bonnet that one uses to jump start the car/ hook things up that need power....
Ha, never looked, never needed to cos my timing light has its own battery source.
https://www.sau.com.au/forums/topic/466604-checking-timing/#findComment-7774463
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
