Hi all i have a few item that have been for my past r34gtt's...
1. KONIG AFTERBURNER WHEELS 18×7.5, no gutter rash or marks great condition.. $600...
2. XXR WHEELS, rears 18×9.5, fronts 18×9, one rim has some marks but not to bad.. $600...
3. BOMEX side skirt's for a R34gtt coupe never got around to fitting.. $75...
4. THERMO FANS AND SHROUD with brand new craig davies thermo switch.. $90...
5. Tein winding master monoflex coilovers only used for around 4 months no knocks or leaks perfect condition and comes with a edfc set up.. $1200...
All parts are located in geelong Victoria and can be posted at buyers expense 391816973ed28a74b91f4b619bcab447.jpg547b0b8075ef858c1d832a5936791662.jpg042d1d7504f152f38e075771d17c2825.jpg9cb4de6f41776a525ba59e2fc9dfaa91.jpg4a0c1fb747c2099c288af923beb90388.jpga1e08c87f9a11cec6885488a2da023a5.jpg
https://www.sau.com.au/forums/topic/466642-r34gtt-parts-and-wheels/
Umm it should be stamped on the spring or a part number stamped on the spring.
Hi bro, the rears are stamped M070-GKC and fronts L080-GSC1. Im not to sure to be honest how to figure it out ive had a quick look on the net but no luck.. i know they weren't to harsh on the road when i had them in my 34 a while back. Cheers
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
