Hi all i have a few item that have been for my past r34gtt's...
1. KONIG AFTERBURNER WHEELS 18×7.5, no gutter rash or marks great condition.. $600...
2. XXR WHEELS, rears 18×9.5, fronts 18×9, one rim has some marks but not to bad.. $600...
3. BOMEX side skirt's for a R34gtt coupe never got around to fitting.. $75...
4. THERMO FANS AND SHROUD with brand new craig davies thermo switch.. $90...
5. Tein winding master monoflex coilovers only used for around 4 months no knocks or leaks perfect condition and comes with a edfc set up.. $1200...
All parts are located in geelong Victoria and can be posted at buyers expense 391816973ed28a74b91f4b619bcab447.jpg547b0b8075ef858c1d832a5936791662.jpg042d1d7504f152f38e075771d17c2825.jpg9cb4de6f41776a525ba59e2fc9dfaa91.jpg4a0c1fb747c2099c288af923beb90388.jpga1e08c87f9a11cec6885488a2da023a5.jpg
https://www.sau.com.au/forums/topic/466642-r34gtt-parts-and-wheels/
Umm it should be stamped on the spring or a part number stamped on the spring.
Hi bro, the rears are stamped M070-GKC and fronts L080-GSC1. Im not to sure to be honest how to figure it out ive had a quick look on the net but no luck.. i know they weren't to harsh on the road when i had them in my 34 a while back. Cheers
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
