HKS Actuator Results on Stock Turbo
Guest Robo's
The big question??? Does the HKS Actuator stop boost dropping up high on a stock turboed RB25DET?? The answer is NO.
Initial instalments werent too good, i was having no boost down low and a little up high, say 8psi at 6000rpm, but 5psi mid range was aweful, explains why i struggled against a VR4 owner. But after some more testings, im getting some mixed results. The problem is i am getting 11psi at 3000rpm, then it gradually rises with revs to 13psi and slowly filters off at the top. But i am pulling at least 1psi more up top and yes it is holding it longer. But i cannot get fullboost down low for some reason. Also, i am not using the bleed valve at the moment.
I will do some more testing. I am planning to back the actuator off a little and fit my bleed valve and raise it from there. Then once i've got a reasonable state of tune, i will whack it on the dyno and monitor A/F ratios and boost levels.
To be continued!!!
https://www.sau.com.au/forums/topic/46680-hks-actuator-results-on-stock-turbo/
so your saying you get 11psi @ 3000rpm ?
And you want more down low?
If so, you aint gonna find much more at all. How early do you think the stock turbo will make 11psi? :consfused:
And actuator wont stop the boost dropping off much at all, as the turbo is just getting out of its efficiency. No gadget (save for a better turbo) will fix that problem.
Guest Robo's
I used to get 13spi with the stock actuator down low.
Definately wastegate issue. Critical to this HKS actuator is the rod length. Any small change in the rod length will result in poor boosting.
The bleed valve has like an inbuilt delay which fights the wastegate creep. Running the HKS actuator by itself and u have to expect some creep, thats how its designed to work, smooth boost transition, not WHACK.
I mucked around with carby return springs on the wastegate flap with my old VL turbo. Worked a treat once the right spring was found, ie not to heavy, not to light.
Guest Robo's
Your right, its a smooth transistion to full boost. I can watch the boost guage creep as revs rise. Time to pull the tension back out of the actuator and bleed some boost into her.
  • 2 months later...
stock turbo, stock actuator, HKS EVC IV, and i get .75 bar from about 2800 / 3000 rpm ish, until redline ...
this bring me to conclude that its all in the wastegate control ... yes, the actuator plays a big part in this, but it also need to be told WHAT to do, this is where the EVC comes in and seems to do a GREAT job at it ...
Try boosting it further and then watch it drop
would prefer not to kill the stock turbo until i have another one sitting on the shelf waiting to be installed .....
If you dont race it on a track, lap after lap, its not going to die straight away. Ive been on 13psi for at least a year now, and i have just taken out my turbo last night and its still as tight as ever.
It's more to do with heat in the exhaust wheel.
If you are running stock management you are less likely to bust the thing as you are when running a PowerFC.
When you lean the mixtures you heat up the exhaust gases and therefore the exhaust wheel.
The exhaust wheel delaminates at very high temperature and it spits itself into the turbine housing, hence destroying the impeller.
BASS OUT
hi flow it or bolt on 2530 or something similar and have no ceramic issues wories, personally i found the stock turbo to be very reliable, i was running 13psi and sometimes 15psi on stock turbo. The oil seal let go and the rear wheel is still all intact although my engine also decided it could handle it anymore so......rebuilding
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
