Workshops west side
:mellow:Hi all, i need a good workshops to install my new clutch and standard car service for my ER34. I live in Altona so any where in the westside. I know there's Chasers in footscray, but i need to know other shops. Thanks for your help in advance.
https://www.sau.com.au/forums/topic/466928-workshops-west-side/
17 hours ago, FiloGTT34 said:
Workshops west side
Edge Motorworks in Sunshine
  • Like 2
1 hour ago, milanr34 said:
Talk to Barry - very friendly guy and he will look after you. Albeit wait after he swaps my turbos please! :P
Get in line!
He's been trying to get me to switch to -5s...feel like it's cause he wants my -9s lol
1 hour ago, Birds said:
Get in line!
LoL, which was your car - he had plenty of cars there.
I have a pair of 25/30's but swapping them over for some 2860-7s, so if i make around 350 im a happy camper.
But yea hes pushing me to e85 and single haha doubt he wants the 9's since he has 7s and is making 355 already. He said next up is single once he gets the haltech.
9s make more power than 7s
I'm all about response. I like to sit in 4th at 100 and have near instant boost at those speeds. In Barry's 34 I had to wait a couple of secs before they did anything. It's a quick car once it gets on though.
E85 is the way to go man, even without a turbo upgrade. So much better midrange.
  • Like 2
6 minutes ago, FiloGTT34 said:
Thanks Birdy for the suggestion to go to Barry. Got my clutch in now and im very satisfied. Barry is a top bloke with a russian mob accent !!
Was that your red gtt or the yellow one?
Hopefully since I understand the language he will do my car first then Birdies haha xD
Edited by milanr34
Ah yea I saw it parked and your new clutch at work! Seems very nice, apart from changing the muffler its looking very nice.
Haha yea thats my 34, but turbo swap, injectors, and a haltech are yet to be done. So ill be waiting a while so I envy you hehe
I used to have a GTT was always fun to slide :D
7 hours ago, Daz said:
Lol -5s laggy must be a shit tuner...
Mine comes on almost instantly :)
If that was directed at me, I mean the lag as in what rpm you ramp up to full boost
I want it from 3500 max in the 26/30
I'm saying my old set up with -5s
A well known tuner (on this forum) tuned it and the car was a laggy pos.
Took it to another tuner and the car came to life, felt like it was 10 times more responsive.
So I'm saying pick the right tuner :)
  • Like 1
Can you PM me both so I may avoid and sway haha
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
