I came across this ER34 skyline, was real interested in it so i did an odometer check and the results are shocking [emoji33]
I went to check it out again to confirm if vin# was correct and dealer said it's sold. I hope he is lieing to me and it really isn't sold, poor person who bought it if it's truly sold.
Pm me if u wanna know more details
Thanks
https://www.sau.com.au/forums/topic/467061-dealer-beware-se-suburbs/
Pretty sure nothing wrong with naming when you have hard evidence for others to judge...it's when people say "this place is shit because I / my mate had a bad experience with them, trust me" that you put the forums in danger of defamation.
We had an Edward Lees thread in general automotive that shitcanned the place and the mods didn't shut it down - think the evidence was irrefutable?
The reality is if you're publishing information that is publically accessible then no crime being committed, especially if all you're doing is stating fact...defamation only applies for things that aren't true or can't be proven.
So I guess in this instance you can't accuse them of tampering with odos, but you can say they're selling or sold a car that auction papers show to be a different condition ;)
  • Like 1
I went to check this out on the weekend and had a chat to the guy that bought it. I told him about the wear on the drivers seat which was worse than other cars showing 140kms plus and that the dealer had re-stitched the steering wheel...
Oh thought he was telling fibs about being sold. Correct steering wheel being re stitch and seat worn doesn't reflect 70k car. But I did take for a spin and was amazing how smooth the motor and gear box was. It was good drive. That why I did odometer check coz I was keen on it.
Www.japaneseodomtercheck.com and they on facebook.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
