R32 GTR Fuse Question
Hello folks, would you know what these two fuses do, "electronic parts" and "transmission control?"
My R32 GTR arrived a year and half ago with those 2 fuses missing.  I have always driven my car without them and I just now notice they are missing.  Have I damaged my car in anyway driving without them?
Thanks in advance for your inputs!
https://www.sau.com.au/forums/topic/467099-r32-gtr-fuse-question/
Fuse #2 (Electronic parts) appears to control only the automatic spoiler and it's computer and switches
Fuse #3 (Transmission control) looks after the auto trans gear selector and computer
If neither of these are working, and should be, then put a fuse in.....otherwise everything is fine :) They use the same fuse box for all 32s with lots of different engines, transmissions, features
Thanks a ton for the information, I got really worried for a while, phew!
I don't believe I have active aero's, so Fuse #2 is likely unused.  And I have a standard R32 GTR, so Fuse #3 should be unused.  Mystery solved, I can go driving again! :)
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
