this is the compressor map for the t04e-60 trim.
it is close to surge line at 1.1bar and 4000rpm but i dont think it will surge.
What are your thoughts.
One thing im not sure about is how to calculate volumetric efficiency at certain RPM. Ive only guessed them as shown in my inputs.
  • Replies 112
Instructions for turbo calculator:
Turbo Map can be used to plot a Turbocharged engine air flow against various compressor flow maps, to determine what compressor wheel best suits your engine.
The points fields are used to plot the air flow at different RPM and boost conditions. It is not necessary to fill in all points fields, just one if you wish.
If the map is too small a bigger map will be shown. You will need to then press the "Calc" button again to plot the points.
The following is an example of using the points fields.
RPM Boost VE Comp Efficiency
Point 1 7000 80 80 60
Point 2 4000 80 90 72
Point 3 2000 5 100 60
Point 1 is the maximum engine RPM.
Point 2 is the RPM where maximum boost is achieved. ( Wastegate starts to control boost pressure)
Point 3 is the RPM where boost starts.
When selecting a compressor that is the best match for your engine, select a flow map where the point the maximum boost is first achieved ( Point 2 in this case) is close to the surge line
This will ensure maximum compressor efficiency through the engines maximum torque RPM.
As I said, your plot 3 is the problem, think about how often you go through or stay in the 3,000 to 4,000 rpm area.
My rule of thumb for volumetric efficiency on a DOHC 4 valve engine is 90 to 95% depending on what's done. A fresh engine with cams and porting etc is closer to 95%, compared to an old engine with stan'd cams and cast ports that would be closer to 90%. Simple :)
I have done it in NSW, a bunch of us got together and the emissions testing facility was closed for 4 years as a result. I have also "been to court" on a couple of other issues (mostly successful) and I have one on at the moment over Speed Cameras and their maintenance. So I don't just talk about it. :)
Sorry for the hijack Enrico....
But - Steve is trying to do something about it. I don't know how far he has gotten with it but i can assure you if i could, i would. It Seems the Government here in SA is setup to cover their own arses, and if you don't believe me, come try for yourself Gary.
Not saying i wont, but there are cases that have been unsuccessful before
edit/ Regency isnt just a testing facility either. Its only one of a couple of places that are authorized to do vehicle safety checks in SA. There is no "pay for your mods" scheme in SA. They even have the right to dissagree with engineers reports that state the car meets EVERY requirement, and still defect you, even though they dont hold a degree themselves.
Sounding fair now? Come try Gary, I'll go to court wit you :D
Don't get me wrong I am not saying it's easy, because it isn't. Sometimes loosing the case is not the real issue, what you are trying to do is embarass the Govt. They want to be elected next time, so bad publicity and the opposition spokesperson can be your best weapons. :ak47:
You are right, all govt's are "set up to cover their arses" but that is your best tactic, expose their arse. You don't have to kick it, just expose it. :shake:
The media will kick it for you. :)
thanks for the ve estimate. So do i use it throughout the rev range...?
Also u pointed out to me a surge problem at point 3. How do i not get a point that will surge at point 3?
A volumetric efficency of 90% and above is slightly optimistic, I would say 85%, better to be safe than sorry. And remeber max volumetric efficiency occurs at peak torque point NOT peak power!!
Peak torque rpm of a standard RB25det is _?
Thats its max volumetric efficency point.
Not wishing to argue here, but just support my rule of thumb. I have seen the test data from Nascar done in 1978 that shows a small block Chevy sits at 85% volumetric efficiency. Smokey Yunik in the late 70's also tested a Ford Windsor V8 and ended up at 86%. Since these are both 4 barrel carburetted engines with 2 valves per cylinder and pushrods, I have no problem believing a DOHC 4 valve fuel injected engine isn't going to achieve another 4%. Then we have the now arguably far superior piston ring and bore composition, not to mention the aerodynamic improvement in valve flows.
So I will stand by my 90% to 95% rule of thumb, at least until I see tested evidence otherwise from a reputable source. :(
thanx for the detailed info sydney kid, im still runing stock cams / head no porting. ive just fitted a stainless steel manifold for the internal wastegated gcg turbo it flows 6 into 4 into 2 just before the flange i think its a copy of a hks manifold, havent had ecu remapped yet but there seems to be alot more midrange torque and top end power, will post my results after i get the car tuned.
What is A/R?
[/color]
A/R
·                  A/R describes a geometric property of all compressor and turbine                  housings. Increasing compressor A/R optimizes the performance                  for low boost applications. Changing turbine A/R has many effects.                  By going to a larger turbine A/R, the turbo comes up on boost                  at a higher engine speed, the flow capacity of the turbine is                  increased and less flow is wastegated, there is less engine backpressure,                  and engine volumetric efficiency is increased resulting in more                  overall power
taken from the ATP Turbo website - click here
So, the A/R ratio of the exhaust housing refers to the size and shape of the scroll that is cast into the housing. It basically determines how restrictive the housing will be, versus how quickly the turbine will spin up. A lower A/R ratio (smaller scroll area, A) results in a more restrictive housing. This restriction speeds up the exhaust gasses and increases the amount that the gasses will expand. It's the speed and expansion of the gasses that causes the turbine to spin. So with a low A/R ratio, the turbine will spin up quicker, but as engine output and rpms increase, the restriction of the housing begins to build up too much back pressure on the engine, which reduces performance. A good rule of thumb for when there is too much back pressure is when the pressure in the exhaust manifold is more the half of the pressure in the cylinder. So basically, a larger A/R ratio will improve your engine's top end, while losing some mid range power and increasing turbo lag. A smaller A/R ratio will help the bottom and mid-range, but may effect the top end.
Taken from the TurboNation website - click here
Has anyone got any experience with running a Garrett t3/t04e hybrid turbo.
They seem to be good for around 500hp, and are not meant to be very laggy.
Does anyone know?
I'm pretty sure that's what I have. I don't have many details because it was already there when I bought the car, and was just advertised as a "450hp T04 turbo". A guy from Garrett in Chipping Norton later identified it as a T04E, but he didn't mention the rear housing which internally gated. So I presume it's a T3/4 hybrid, although the exhaust housing doesn't look the same as the VL turbo housings I've seen.
Not having driven a turbo car with a state-of-the-art HKS or GT Garrett turbo I can't really comment on the lag, but I've been a passenger in an R33 with a stock turbo and mine doesn't seem too bad in comparison. If I launch at about 3000rpm it does so decently without bogging down. I can't remember when exactly full boost (15psi) comes on but I've mentioned it somewhere in another thread. I think around 4000-4500rpm.
I had the car tuned with an S-AFC before at 1 bar, and it got 215rwkw. This wasn't quite maxing out the injectors or the AFM. After I swapped the S-AFC for a PowerFC, it then maxed out the injectors and AFM at 0.9 or 1.0 bar. So at a rough estimate I would say that it's now getting around 215rwkw or a tad more at 0.8 bar.
It's not the turbo I would have chosen if the car didn't come with it, unless it was dirt cheap and I was poor, which it is and I am. I'm guessing the previous owner thought the same thing. Depending on price I think it's a good turbo, and you could probably get one for half the price of a GCG 450hp factory rebuilt one. The exhaust housing is rather small, if it is indeed rated to 450hp I could probably get more out of it by getting a bigger exhaust housing for it. The compressor is .6 AR.
Other things to consider are you will need a new dump pipe, so try to find one that comes with it to save some money.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
