R33 Horn wiring
96 R33 gtst S2
G'day could someone please shed some light on how to wire up the 33 horn on an aftermarket wheel
I have searched absolutely everywhere and have found nothing helpful at all I understand how to connect it but I can't seem to get any response from any of the wires
For starters the horns work when I put a feed directly through them.
i have replaced the relay
i have changed the fuse to rule that out also and I have tried testing different wires and earthing wires out which i understand the horn works when earth contact is made
I have 2 wires on a block connector which I know are for airbags then I have 3 wires which have been cut being blue red and yellow (photos below) and I have tried multiple connections and I can't get anything out of it..
i have the whole column apart and I can see the wires that would run through to the factory wheel but Im having a real crap time
can somebody point me in the right direction
https://www.sau.com.au/forums/topic/467467-r33-horn-wiring/
Horn works all the time, So ground each wire individually with the car off. Horn should go off when the wire is grounded.
If it doesn't, you may have a wiring issue (if you have already checked the fuse and the relay)
I have a wiring diagram for it but cant upload images at the moment for some reason
https://www.sau.com.au/forums/topic/467467-r33-horn-wiring/#findComment-7786852
