I've been looking into one of these "billet" intake manifolds that have been doing the rounds from Otaku Garage and a few other lads who all get them through Alibaba I assume....
I wanted a nismo plenum but I can't justify $2k+ for a plenum.... Especially not when these are going for $700-$1k
One particular seller is offering them much cheaper than others I've seen and is also offering an option of having velocity stacks inside the plenum.
I'm only really interested in the rb26 individual throttle plenum as I run GTR throttles on my rb25.
I'm aware hypertune, plasmaman and JUN all run internal trumpets in their plenums and thats enough for me to believe it's a good thing to have.
I've been told by another seller who doesn't offer the stacks option that that are a hindrance to flow and performance inside a plenum..
What's your lads thoughts on all this? Stacks or no stacks?
028833c3cad0686b02ba5a58cf39491b.jpga49428f1b2742b50b27a2d2c0eee803a.jpgec3ae20fd8705813db5b3a5565190af8.jpg
They have flow tests of these manifolds without the velocity stacks vs stock manifold and it was extremely pleasing all cylinders with were very close compared to the oem which didnt supply enough to cyl 5 and 6. They dont have flow tests with velocity stacks so id probably opt out on them
Let's be clear.  Trumpets inside a plenum do NOTHING to improve distribution between cylinders.  The only reason to have them is to obtain the total runner length that you are after.  If you are so fussy that an extra 10mm of runner length is enough to make you put trumpets inside a plenum to change the tuned rpm of the inlet by, what, maybe 200rpm) then go for it.  But in general it is a total WOFTAM.
Many very scientific (and by that I don't mean MightyCarMods scientific, I'm talking Society of Automotive Engineers type scientific) tests have been done that prove that best inlet treatment is generally just a rolled edge on the floor of the plenum.  That's like the top of those trumpet bells that roll all the way back on themselves.  So it's like having half a donut around each runner opening.  The donut being sliced longways through its equator.
The next best is just a decent bellmouth buried completely in the floor of the plenum.
Unless a plenum is a big box and the air flow is coming from somewhere different (to what it does in a typical RB plenum) then trumpets sticking up into the flow can usually only cause turbulence and mess.  Unless someone can show you serious physical modelling/testwork or good quality CFD results proving that they don't hurt, it is safest to assume that they will.
The biggest and most important part of a plenum is that it should be large enough and shaped such that it will do the job it is asked to do - being to distribute the flow evenly.  My comments about testwork or modelling from above apply here too.  Unless it is a direct copy of a known good design, it may be safest to assume that they don't do all that they are supposed to.
Would caution against looking into "flow" numebrs of manifolds.
Eg somewhere it's claimed that the 26 ones flow twice as much as a stock 26 one.
That's nice but think about it unless you have 800kw are you going to have that much aie moving through your plenum?
No.
What is important is how it behaves, which may or may not have relationship with the maximum flow.
No.
Yea of course, the maximum numbers dont mean a hole lot but more so that they claim all 6 cylinders are very closely balanced as apposed to the oem one.
I'll have mine running a stock plenum with per cylinder egt's in a few weeks hopefully, will be able to see how the stock one performs decently well then
This will be valuable info man! Awesome stuff... What's your engine specs?
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
