R33 GTR 105,000kms $22,000
Up for sale is my 1995 Nissan Skyline GTR. I purchased this car as a bit of a project but have since bought another car and lost interest.
I bought this with a blown motor but have since got another low milage running motor for it and had the head fully reconditioned, bottom end inspected which was fine and put a genuine Nissan VRS kit through it. I have taken the car for a few drives since the new motor has gone in and it runs flawless. I was getting this car ready for a roadworthy but it has just sat under a car cover for a few months so I have decided to part with it. All reciepts since I have owned this car will be supplied (over $2000 spent not including the motor). It will come with no RWC, rego or plates but as far as I'm aware will need 4 new tyres, possibly the rails fixed and that's it to pass a roadworthy.
Car was tuned by RacePace when it was owned by the previous owner at 325.6kw atw but the boost controller has been removed so is now running wastegate pressure on the tune.
Blitz coilovers
Buddyclub P1 18x10 +12 wheels
Adjustable front and rear camber arms
Adjustable front caster arms
New sway bar links
New driveshaft boots
100,000km major service was done before I purchased the car and confirm the timing belt, water pump and tensioners are all near new.
-7 turbos
Adjustable cam gears
Splitfire coilpacks
Custom twin 2.5" exhaust (seperate off each turbo)
Alloy Koyo radiator
ARC airbox
Cooling panel
Oil catch can and washer bottle combination
Bosch 1000cc injectors
Power FC D-Jectro with MAF sensor
Walbro 400 lph fuel pump
Brand new Exedy heavy duty clutch with freshly machined flywheel
Nismo 320km/h cluster
Nismo shifter knob
Triple gauge cluster
Nismo clear indicators
The bad:
Chassis rails have been jacked up off of and have crushed them on both sides but they are very repairable (pictures supplied).
Paint is cracked on the front bumper.
Spoiler is fibreglass and paint is cracked but will come with a genuine wing that needs paint.
Car needs a good detail but will come up really well.
Any questions text me anytime or call me after 5.00pm.
I have been as truthful as possible with this ad so please don't come see the car pick on it and low ball me I will tell you to leave. The modifications alone exceed the price of the car so I think it's a very
good price.
I am not interested in swaps as I have another car.
Car is located in Geelong, Victoria
$22,000
David
0447 triple nine 751
Edited by Muratori
https://www.sau.com.au/forums/topic/467729-r33-gtr-105000kms-22000/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
