Josh's NM35 Version 2
joshm35
 Share
Is she running yet ? , I see you got rego plates on it.
was it hard getting blue slip
That plate is there because i had to leave it on the street overnight. (Live in unit block and manager is a w#nker) so not rego yet. Still heaps to fix on it (driveshaft boots, lower ball joints, new hub bolts)
We have been able to locate the issue and will have the locksmith sort it. Appears to be a faulty ICU box (in ignition tunnel).20161210_172720.thumb.jpeg.fcee3b5ca31fb
Can't get over how many speakers there are, and the audio setup in general... seems quite smart.. you can buy a centre speaker from alpine I think that may fit a touch better where the screen was.. I'm guessing it's all more reasonably priced in Japan hence the amount of work that was done [emoji736]
  • Like 1
I have made a harness and will be testing the ICU on Thursday. I have removed the carpet as its not in the best shape and tidying up the audio components as well to find why the food screen is not picking up the video input. . Engine hoses and bolts ahve been vhecked and tightened as there were a few that were loose. Next to get her started. I have located another ignition barrel and key to replace the faulty one along with other items such as carpet, radiator overflow tank, washer bottle and pumps, battery cover, interior bits to replace the speaker panels in roof whrn i tidy up and conceal the audio.
20161213_170410.thumb.jpeg.9bed12d3c997120161213_170324.thumb.jpeg.edfb240bef74620161213_170320.thumb.jpeg.4e12467b6c8e020161213_170316.thumb.jpeg.f08731f0c9e7820161213_170304.thumb.jpeg.f2e03f133d87620161213_170257.thumb.jpeg.7e4c3bc8e4b0520161212_195646.thumb.jpeg.e8b70b2909917
  • Like 1
Josh, a mate just messaged me and said you have advertised the speaker pods for sale.. I'm interested if the freight to Sydney isn't too ugly..
Shoot me a message. Will be under 20 depot to depot
Been a busy night. Sub enclosure, false floor, amp box , amps & sub removed. Also removed the rear hatch screen and excess wiring not required. Looks alot cleaner now. Plan is to hide everything for a more cleaner look. 20161215_203648.jpeg20161215_204810.jpeg20161215_205753.jpeg20161215_210708.jpeg20161215_210746.jpeg20161215_211830.jpeg20161215_224204.jpeg20161215_225402.jpeg20161215_230940.jpeg20161215_230955.jpeg20161216_001701.jpeg20161216_001715.jpeg20161216_001723.jpeg
  • Like 4
Gee for a bit of bass, I'd be sweating all the time of getting a flat...
At least you could listen to awesome sound while you're waiting for the tow truck.
Run flats ?
Yeah as i need to register this and do a road worthy im planning on putting tge spare back in and putting the amp on the under floor tray like i did my last car. That way i can have both. Picking up a spare gearbox today and will be swapping over the speed sensors as i have a 16 flash Check AT error code (Speed Sensors). Im not sure which one so ill swap out both.
Very productive day today. I have a 16 flash AT error code which relates to the transmission speed sensor. I have sourced a spare gearbox where i have taken the valve body out of and swapped it into the m35. 20161217_133907.thumb.jpeg.4407024403a8e20161217_150943.thumb.jpeg.8c5c588bc42ea20161217_153641.thumb.jpeg.a4161fa52b42b20161217_153651.thumb.jpeg.df8bcb58dc05720161217_174749.thumb.jpeg.874126ff570a220161217_181208.thumb.jpeg.16165b75ad433
  • Like 2
 Share
    • Does this count as a time trial as well? I got all gold in the master super licence (1 lap time trial) and received a McLaren MP4/4 for my trouble.  If anyone else has done this, did you ride the wall right around the first long right hander at Lake Louise snow track to get gold? I couldn't do it any other way... best I could do without riding the was was within 2 tenths of the gold time.
    • I definitely get the low power, sporty car to drive to smash gears but not be doing eleventy million miles an hour! It makes all the normal drives fun!   Rev match tune sounds like the funs! I didn't know the NC had a DBW throttle!   As for me, still have the Skyline, it still has the Barra in it. It's been pushed to the side of the workshop at the moment. Pretty much waiting on me finishing the wiring, and dropping new fuel lines in. Got myself an ACDC Tig end of last year so been teaching myself TIG welding to build a few things for the Skyline. The missus wrote off her GTB liberty at the end of last year, and got it back on salvage rights stupid cheap. It's also still registered, so will mean easier for me to take to the track already done most of the panel damage, just playing "clear the workshop" to make space to pull the motor and box out, fix some oil leaks, replace the clutch, and replace a few minor broken things.  Also got a Lathe at the start of the year, which is adding to the annoyance of no space, which is another reason I'm trying to build things to get more space, to get the Lathe back in a final home for it. It's a BIG lathe, can turn a 355mm diameter, and 1metre between centres... Got it at a steal! So between it and the TIG and old MIG welder, I'll be fabbing some fun little shit up But we've had a lot of shit stuff happening at home, so it's slow going getting things done. But one step at a time!
    • I love Catalunya.  Got a 1:54.632. The AMG is a hoot.
    • I hadn't got that far, my main worry was the connection to the actual calipers themselves. I'm just using new (ish) stock brake lines in the stock setup. I've just had a stud welded to the knuckle that is a little lower than the original stud (so my knuckles have two studs each side) to not have it be stretched so far in previous BBK setups, so the "block" (in the second picture) mounts a little lower for me and I hope I don't need to change anything. I may have even changed the connection to the calipers in the past and have since forgotten I did that. I may not have. Guess how I'm gonna find out. Source: hopium
    • It's more so I'm using the 1x piece line from HEL that goes from the body to the caliper. There's no middle block/mount like the HFM ones or the GKtech ones. There are certain angles/suspension compression where the line actually slightly contacts the ARB. Below of how mine sit (not my photo): How I want it:
