My build is almost there ! Just need your help please !
alright guys I am new to sau. I am the new guy from the u.s I posted in the n00b section .
Anywho ..
So my car 96' bcnr33 , is running rich as f-word
i am running a step up on the turbos ..
i am told by pureturbos.com when I sent them there to be rebuilt thinking it had garret  2860's that I actually had a set of journal bearing nismo/garret turbos that will flow ~375hp each so when I got them back I ported stock exhaust manifolds and bolted it all together.
The car was originally map sensor on a fcon pro 2.1 with a atmosphere bov
i couldn't find anyone in the u.s to tune it so I bought a power fc and afm's because it's a more accurate way to measure for my power goals . 400-500whp whatever it makes it makes
problem is that right now I want to know if I should recirculate for engine/turbine health and longevity or if the power fc can adjust for when the bov dumps the boost??
my specs are
ati balancer
forged pistons
Hks 3 row intercooler
3" intercooler pipes and
Aeromotive fuel reg
stock inj
stock cams as far as I know
turbos mentioned above
hks evc boost controller
triple plate clutch
aem wide band needs to be put in
not sure the model fuel pump but I know it's bigger too
i have rc 750cc injectors with clips that I need to put in
what kind of WHP would I be looking at?
my filters and intake piping might be holding me up ? What do you recommend there ? I want to replace the rubber tube I have my chrome intake tube into if I can
Also the tach and speedo are not functioning but fuel and engine temp and oil pressure are ..
basically I want my car to be clean I have already done a lot im closing in I just need a little  more help
to re cap
Can a power fc with pro software be tuned to minimize harm from atmosphere bov?
Wht kind of power is possible with my upgrades?
How can I adjust stiffness of hyper max 3 coilovers ?
what should I do about my intake/filter setup ? the rubber intake ripped so a shop just chopped it back and gave me that .
How can I fix my tach and speedo ? Or good deal on another one .
Car is on stock ecu and fuel pressure dialed back down and running running pig rich before I put my new power fc in since the old one broke.
Also, anything I should know before going to a dyno as far as the motor goes? I have a fresh set of Ngk iridium plugs for right before
I don't trust the shop it was at they screwed me so I have to comb back over everything before it goes to the tuner
Thanks
Chris
i will upload load more pics if you want let me know
More pictures bottom picture  is why I don't trust shops I took my bumper off at home when I pulled the car out of the shop for them slacking and not figuring it out and found it that way on both sides.. they expected it to run like that said it kept fouling plugs with a fried power fc plugged in and couldn't figure out why it was fouling plugs LOL Idiots. I had them pull the ecu and I sent it to apexi they said injector driver was blown. I bought a new power fc and pulled out of that shop. I'm trying to dial everything in for the dyno so I don't show up unprepared
Where to start.
I don't expect your car to be drive-able by the time you have done all your mods - it will need to be towed/trailered to the tuner.
It would have been easier to replace your F-Con with a Link - then you could have stayed with MAP sensor instead of AFMs
You need to work out what your power goal is first - you reckon your turbos can make 750hp in which case stock GTR AFMs and injectors won't do it. Ideally especially with AFMs your BOV(s) should be plumbed back but tuner may be able to work around that. Have you got a 3.5 or 4in exhaust all the way through? What are you using for wastegate(s)?
Intakes should do for now. Old coils can let you down so if they are original you need some new OEM, Splitfires, or something like LS2 Truck coils or AEM coils.
I have not worked on a GTR so other owners will have some more/better info for you.
I have rc 750 cc injectors I have to put in.  I plan on doing plugs swapping injectors in and going to the dyno I was using the stock ecu for troubleshooting and fault codes is there anything else I should do ? As far as the bov is it going to be an issue for longevity or just kinda like not a huge deal ?
Not sure what wastegates I'm running I bought the car modified with the hks map sensor setup no one could properly tune it    Tho so I switched to the power fc
Edited by R33gtr520
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
