Hi,
I need someone in QLD who can tune this ECU, Gavin Woods can't, Sub-Zero can't, all the HKS dealers can't.... I rang up BD4's in Sydney which is a HKS ProDealer and they reckon they are the only ones in Australia who can tune this ECU. If anyone knows of workshops in QLD who can do it let it be know :)
Otherwise I will be going on a little roadtrip ;)
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/
  • Replies 74
be careful with the HKS Fcon V ecu's. Not many around australia know how to tune them because most the time the language is in Japanese and u need HKS accreditation to recieve access to the software. Only time i've heard of ANYONE in australia tune one was when Susumu Koyama from Jun Auto in japan went over to perth to tune a few cars (inclusive of a sexy looking grey R34 GTR)
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-950906
I just spoke to Jim @ Croydon Racing Developments (CRD) and he is trying to source the HKS F-Con S/V laptop software from HKS at a cost of $4000 so he can tune this excellent ECU...
Just remember that actual costs always run nearly double what he quotes you. Keep that in mind and you'll be fine.
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-950907
;) um, you could pay twice the money to get something like that tuned..
or throw it out and go for one of the common ones that can be tuned by anybody. Its a waste in a way, but unless you can find a good tuner for it, what is the point?
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951015
Ok the deal with HKS computers as far as i know is:
FconV
Does fuel only. Now the bad thing with this piggyback ecu is that the standard ecu will still retard timing and add/remove fuel 7.5% either way of the tune put simply. I like to think of it as HKS's answer to the SAFC. Who would pay someone big money to tune an FconV or FconS when you could get an safc done for 200.
FconV Pro
Does fuel and timing and shitloads of other stuff, comparable to a motec, but still not as comprehensive. With thi ecu you have to buy an air temp sensor and a MAP sensor to make it work, an additional $1000 ontop of the ECU. Also it is still a piggyback, leaving the standard ecu to do aircon and demister etc. the fuel/timing is eliminated with a special harness which isnt cheap too. Tuning was very expensive last time i got a quote, it put me off getting one of these ECU's. Imagine forking out truckloads of money everytime you do a mod just to tune your car to it.
-rb25
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951147
Serious question, and not a go at you or anything....
If its a step below the PFC, and you have to drive from the sunny coast to sydney for tuning ... Why use it instead of the PFC?
If there are some magical features ross hasnt pointed out yet (although I guess MAP is an advantage over MAF) I'd be interested in hearing them. Always open to new ideas and suggestions for ECUs :rolleyes:
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951859
rb25 the HKS FCON V is worlds apart from the Apex SAFC, maybe one step behind the Power FC, for reference I have the Pro Version and BD4's do have the Pro Software.
for sure, it is more comprehensive than an safc, but at the end of the day, it does fuel maps, not timing, and imho thats ordinary anyway. powerfc is the go.
-rb25
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951880
In Perth a guy is flown in over from Japan and all cars a done in one hit, it isnt just about having the gear and software it is all about knowing how to tune the software.
One shop here blew two motors and they hadent started to look into tuning, ripped it out and put in a Micro Tech (RX7).
Power FC is the way or something that a good local tuning shop can work on.
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951891
Because it is the pro version, which is proven a better ecu over the apex power fc.
The pro version is pretty much a MoTeC but uses a piggyback system.
And yes RB25 I have the harnesses and what not.
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951947
i believe what Krawler is trying to say is ---> Why is it so much better than the Power FC? therefore making the drive to sydney worth it. Why couldnt u sell it buy a power FC and have it tuned here and save yaself alot of trouble
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-951985
you can now get a newer PFC's will do MAP as well..
i think everybody is pretty much along the same lines though.. $1200 on a PFC, or lots of ****ing around and maybe headaches with the HKS. The HKS may in fact be a better ECU, and I have seen quite a few hypo GTR's with them in japan - and some 9second GTR have had them.. but if you can't get it tuned, or tuned properly more importantly its all a little irrelevent
https://www.sau.com.au/forums/topic/46850-tuning-hks-fcon-v/#findComment-952358
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
