M35 Electrical gremlin
Hey guys,
I have quizzed a few of the facbook users in the M35 tuners group about this issue, but thought it might also be a good idea to see if anyone on here has any ideas that havent been thought of yet.
For the better part of six weeks now, i have an issue with the car whenever it sits unoccupied in the sun (like carparks when shopping, or in full sun at work). The car shows on the dash firstly the AT light, and also drops out the speedo and gear selection on the dash. Then once the ABS decided s to do it little venting test on start up, it seems to hold the "vent" open for about 20-30 seconds, the the light stays on.
I have been in a few positions when i have had to move the car with the issue present, and without jumping on the breaks, there dosn't appear to be any major noticeable issue with the breaking, but the trans is clearly unhappy. It slams pretty hard from N  to D and it holds the gears a lot longer then it normally would.
Then, once the windows are down and the cabin of the car cools down, slowly the AT will go back to normal then shortly after the ABS light will switch off.
Also, to test the theory, i had parked the car in full sun yesterday (about 30 degrees) and cranked it over at about 4pm, sure enough the issue occurred. i then moved the car to the shade, left it with windows down for an hour, then fired it up again, no issues present.
I had read on here that a faulty atessa ecu had caused ABS issues in the past, but there was no mention of faulty gauges with that. And also from what i have been told, the gauges are controlled by the iPDM, but that should not have any temp change in cabin as next to the battery.
I have a new iPDM, BCM & ABS ecu coming from Josh, and will try those but does anyone else have any thoughts or had similar issues?
https://www.sau.com.au/forums/topic/468553-m35-electrical-gremlin/
i probably will end up replacing the yaw sensor as well as it has seemed to solve a few peoples issues, though from what i had read on here, they were all involving the 4WD system to some extent, which mine seems to be happy with at the moment. But it does appear to be a cheapish fix if that is the problem.
So after driving the car in decent rain for the first time since this issue as popped up, after drive for about 10-15 minuets without issue, i attempted to pull into my driveway for work and the day died, just a very quick loss of power and then nothing. Turned it off and back on an the idle was rough and really low, on the brink of stalling. That lasted for about 30 seconds, then i fired back up to normal and off it went. I drove a few hundred meters and then started to break, and the rough idle happened again.
Im assuming that the breaking motion is sending water towards the nose of the car, and that is somehow either messing with the current issue, or creating a new one all together. Also, theres no bung below the battery, so any water in there should be draining away but with the battery shroud on it cant see.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
