120% happy with mine.
I have HKS Dump, Front pipe and Cat back with Super Drager muffler.
good power but fairly quiet.
I have been toying with the idea of ditching the resonator to pump up the volume a little.
In my opinion that bigass muffler and 5" tip looks the goods with the 4" pipe leading into it visable from the rear of the car as well.
Good system - not too droney at cruise but wakes up when you give it to it.
Not too restrictive on moderate power applications, but will know for sure in a few weeks when the new motor is back in (with considerable more power)
  • 4 months later...
I'm considering using a 2nd hand Super Drager cat-back exhaust from a R32 GTR on my R32 GTSt.
Would it be noisier on the smaller engine? Would it be noise legal? Are they 90mm?
Are they full stainless steel or mild steel with SS rear muffler or available in both?
agreed mate, looks great not too noisy and the rear muffler does look pretty fat! :)
they dont make brand new ones anymore but there is a similar one called super silencer i think its called that its 3.3/4 inch, if you are buying a second hand one ive seen them go for less than $700, what you could also do is just go to your exhaust place and ask them for a quote on a 3.5 mandrel bent full exhaust, as long as you buy good brand mufflers and cat converters it wont be too loud, you dont need stainless i think that its a wank factor cause its shiney and looks good, you would save hundereds getting it made out of mild steel. its completey up to you what you like, i priced the HKS exhaust brand new and it was well over 1000 and that is just for cat back you could get a full mild steel exhaust with good mufflers and cat for that price.
yea i got my super dragger installed with a high flow cat and 3" dump pipe i love it. I was worried about it being to loud but was very pleased when i turner her over to find a nice little rumble from the back at idle then when you open her up she puts up a little bit more noise but again nothing over the top
it is very quiet but very high flowing at the same time.
Nigels supra has this exhaust and he gained 30rwkw when he changed from a twin 2.5. and we all know that his car is HIGH powered.
i have this with full exhaust on a rb20 and a friend has it just cat back on a 33. mines quiet, and his is very quiet.
Highly recommended, but as noted, HKS no longer make them due to the tightening of noise regulations over there. I have one on my R34 (stock front pipe and cat) and it didn't even trouble the engineer (only 82db @ 4700rpm). Looks the part too!!
  • 3 weeks later...
I run with the resonator - doesnt restrict flow at all just takes the drone out. It's a pretty big resonator, so without it I personally think it would be as loud as a bitch.:Bang:
How many of you guys run it without a resonator/middle muffler ?
Just dump pipe - front pipe - cat - pipe - super dragger ?
For those that do - do you think it's legal? does it drone? loud?
hey guys are all the hks exhaust systems only cat backs?
i have a straight though 3inch + 3inch dump pipe and its very loud
what would be the difference between the hks exhaust and just a normal 3inch exhaust system??
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
