  • 4 weeks later...
I was hoping Sauber would go back to the jellybean mags of a few years ago :(
New cars look good though - the lower, wider rear wing totally transforms them. Not liking any of the liveries other than Williams yet... Too much fussy gold on the Sauber. Too much black on the Renault which hides the car's shape. And Ferrari's are supposed to be red.
Keen as for the racing to start - Pirelli reckon they'e actually made tyres not designed to degrade so they can actually drive them hard in the race, and corner speeds should be pretty epic. Hopefully that's right and the fast drivers get some reward from it, instead of it being all about tyre management.
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7812792
FB_IMG_1487671484944.jpeg.57a65db47b03eb5c59373f2b4faf090c.jpeg hoping this isn't final... Too much white for my liking
I believe Ferrari said they were going back to the old days and were going to get rid of all the white
Or maybe that was black they were getting rid of....... pretty sure white
I actually like the new sauber. I think it just needs a major sponsor. Sidepod looks a bit bare
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7812807
Fingers crossed...
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7812811
That STR is quite blingy...
also how does everyone feel about the Shark fins? I liked them when they had them years ago and I still do, well some of them... some look shit, usually the ones that are squared off at the back, cant remember which team has it
https://www.sau.com.au/forums/topic/468667-formula-1-2017/#findComment-7813624
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
