Post up what you'd like to achieve (and the budget!) and we can offer some advice.
Try to set out what you want to do with the car and set a reasonable / specific goal for what you want to achieve - what you need to do / buy then flows from that.
Trex is on the money, read up on some of the other build threads or dyno results threads under "Forced Induction Performance" to see what others have done and it will prove invaluable to see what needs to be done and gives you an idea of the sort of costs / parts involved to get to that power level.
At an absolute minimum you'd be looking at:
$800 to $1.5k+ for a turbo (depending on what you want + extra if you decide to go for a better manifold)
$1250+ for a plug in like an adaptronic / nistune / link etc plug in
$600 for decent injectors
$200 for a better fuel pump at a minimum
$500-$1.5K for misc crap  for making the above work correctly or fix other problems you come across while doing it
$1k - $2k for a clutch to handle the increased output (if required)
$??? for any workshop work to fit the above (if not swinging spanners yourself)
$??? for tuning - highly dependent on who you go with
  • Like 1
The AFC is a nice bit of kit when turning up the boost a little on a standard car but at ~450hp at the wheels you are going to be asking for a lot more than what the AFC is capable of safely / sanely doing. The plug in will give you much more flexibility and safety in the tune, not to mention being far easier to tune and a better base to build modifications off.
Checkout www.apexi-usa.com/manuals/electronics/neo_manual.pdf
I have never used one personally but I am well aware of how it works. The sort of modifications that you are looking at is well beyond what this would be able to handle as it is really only meant to be able to manage fueling on a relatively stock engine and not deal with massively different injectors and a much larger turbo etc.
With what you are doing the nistune is an absolute minimum and really the engine management path you take is sort of dictated by who you are getting to tune it - you will get a better result using what they suggest / prefer rather than one they dont know / can't tune properly.
If you are poor don't buy rubbish you don't need. Just try to save up a few grand and in the meantime do some reading along the lines of what you have been advised above. Sell the AFC Neo.
Just to spell it out none of the items on your list will make your car go faster.
And don't feel bad that you don't know enough - we all have to learn - some of us the hard way by spending a lot of money that could have been used more wisely - so don't be in a rush - you can't do much until you can afford a bigger turbo and the bits needed to support it so just keep researching and saving!
  • Like 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
