Hi just got a dremel and kinda new to it. .. wanted to prep my caliper for paint ... anyway did i f**k up? Can anyone with a dremel teach me what to do? It is still smooth to the touch though and i was using the sanding band. Don't know what grade it is. .. was using the coarser 1 initially and i think it's making a lot of scratches. .. so used the less coarse 1 after that. ..
Thanks for any tips!
You just need to hit with the hand and get it all smooth and most of the imperfections out.
There is no need to go to bare metal. It would take longer and with a dremel probably score it
Delicate things are always better by hand.
I initially did it by hand and omgwtf... too much cussing and too impatient. .. with a dremel it was a breeze and of course i think i might have scratched it a bit too... but thanks for the tips. I guess I'll start priming once i feel its ready. ..
Im prepping my calipers for painting aswell. I just dremelled the rough areas smooth as well as all the writing but the nissan. Now in the process of sanding them all down thoroughly with 180 grit.
Just take your time and sand them thoroughly until you have a smooth even surface. It will take a while but its the best way.
Better off buying a pneumatic buff gun/gasket sander or a die grinder and wire wheel to do it. Can be far more delicate with both. I used my buff gun to remove casting marks off cam covers and then wire wheel all the crap off then give it a hand sand to prep. Don't even remember what i used on my brakes. Probably a scouring pad and some sandpaper. They are still fine 5 years (or more) later
Did u use the sanding band? For me i used these 2...
1485574640732.thumb.jpeg.aa83fd140d3816e
Flat 1 for hard to reach area. ..
thanks for the rest of the input but since i already bought the dremel might as well use it and see what other dremel users do
I just used a thick cutting disk but was very careful. Then just sanded with 180 grit. I have a bit more sanding to go but this took me about 10 mins.20170128_183414.thumb.jpeg.132192699c77b20170128_183443.thumb.jpeg.cc6716717023f
I just used a thick cutting disk but was very careful. Then just sanded with 180 grit. I have a bit more sanding to go but this took me about 10 mins.20170128_183414.jpeg20170128_183443.jpeg
Fooking hell...tell me you're joking ... cutting disc. I've got a lot to learn. But how about those angled spots?
Just have to be careful with it. That being said i can just see a few dremel marks underneath the paint.
Just do the angles spots by hand.
As others have said no need to go to bare metal and its better to just do by hand. 30 mins of vigorous sanding is all it takes.
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
