  • 1 month later...
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 6 months later...
There's a nice silver gtr from Tas for 40 on gumtree. I had a full mechanics report done on it, so if you want I'll save you the hassle and email it to you.
https://www.sau.com.au/forums/topic/468996-wtb-r32-gtr/#findComment-7864298
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
