Love hate relationship, help needed
89 R32 GTR 35k miles, has a misfire at idle that gradually gets worse as i drive the car for a long distance. Doesn't break up under load & seems to run well. I have been ripping my hair out trying to figure it out. I have given up & decided to reach out to the SAU community for any help. Below is what i have done to try and subside the infamous misfire. Thanks in advance for anyone thats willing to help me diagnose this turd.
Heres a list of everything i have done. Motor is stock other than exhaust, filter pods & ls2 GM coils.
New oem nissan 02's
New oem TPS
Used but cleaned & tested oem Injectors
Battery
Fuel pumps
Fuel filter
Re-sauder mafs, borrowed known working mafs
GM coil conversion. Reinstalled original coils, no change.
Borrowed ECU
checked all sensors on scanner, ecu talk & snap-on modis. Checked cylinder balance & hooked up oscilloscope. Also ran an injector balance test.
Replaced chassis/motor/battery ground cables.
Spark plugs @ 0.8 gap & 0.7 gap. Tried bcpr7eix & copper core ngk.
New temp sensor.
Sprayed non chlorinated brake cleaner everywhere looking for vac leaks.
Compression test was 150 psi across the board.
https://www.sau.com.au/forums/topic/469178-love-hate-relationship-help-needed/
Have you tried unplugging coilpacks and injectors one at a time to see if there is a problem there? Yes I know you have done the coils and injectors but perhaps there is a wiring harness issue.
Do you know what AFR's the car is running when it hits the issue?
Base timing OK?
Base timing set at 20. Timing doesn't jump around when the misfire hits. Alpha tables are at around 95 on b1 & b2. I can shut off individual coils through MODIS & each one gives a very noticable change. Same with injectors.
Going out on a limb here... I had the exact same issue. Turned out I had a faulty injector. Test resistance in the injectors... look through my profile and you'll find a post I've written up on it. I had similar issues to you... car would sound like dog balls on idle and under high load I had a small misfire that I couldn't notice without looking at afr's
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
