Haltech 2500 Elite, Precision 6266 CEA GEN 2
Hey guys up for grabs is a Haltech elite 2500 with a patch loom by haltech to suit an R34 GTR. ECU has only been in the car for around 10000km max im sure anybody shopping around knows the capabilities of this top of the line ECU. $2800ono.
Next up is a Ceramic ball bearing Gen 2 Precision 6266 turbo with a .84 twin scroll V band rear turbine housing.
As you can see it has a 90° elbow welded onto the compressor cover so she's ready to bolt straight onto the side of an R.
Peak boost ran was 24psi and was on the car for around 7000km max
Perfect condition absolutely no shaft play or damage to compressor wheel or turbine wheel.
$2100ono
Items are located in Penrith area Western Sydney pick up preferred but happy to send anywhere at buyers expensive.
Prices are open to negotiations and if you want both items I'm sure we can work out a good deal.
Had a few people ask me if the loom adapter will work on their 33's. Unfortunately i cant answer that?
Can 1 of you GTR heads answer this question?
Also prices are ono so save your time and mine offering me $1100 or $1200 less than asking prices AS THATS NOT OR NEAR OFFER! ???
Will try my luck here and throw up my  Manley 2.3L stroker kit for a 4G63 85.5mm 9.5:1 compression pistons with turbo tuff I beam rods and forged 100mm crank. Brand new in the box. $2900ono.
Pics coming tomorrow
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
