R33 GTS/-T sales brochure from Japan
For sale is an R33 GTS/-T sales brochure in good condition. It is 27 pages and has some nice photos and interesting pictures relating to factory options. It's all written in Japanese but I'm sure google translate could help out if you were keen.
I found it at a second hand shop in Japan and I thought someone in Aus might be interested.
I bought it for $10 aud and i'll sell it for that + postage.
https://www.sau.com.au/forums/topic/469528-r33-gts-t-sales-brochure-from-japan/
  • 3 weeks later...
  • 4 months later...
