Newbie
Hi everyone,
Im Sammy and I'm from Queensland, Australia.
I am a car enthusiast and want to learn as much as possible.
I own a 1995 r33 GTST, which is pretty well stock at the moment apart from the fmic I finally had fitted just today. ??
I have joined this page so I can learn, ask for advice and make race car friends.
Please be nice and friendly ?
  • Like 3
https://www.sau.com.au/forums/topic/469547-newbie/
Thanks ?
Yeah sure, I've attached a picture.                               I will have to send an updated one in a couple of weeks, I've got some tein coilovers on their way and a set of wolf s1p, so I'm pretty excited for that ?
  • Like 1
https://www.sau.com.au/forums/topic/469547-newbie/#findComment-7816418
  • 1 month later...
Thank you [emoji4]
I'm happy with the looks for now but I'll eventually look into getting a tough looking body kit. Power wise though, I think about 350-400hp on 14psi should be enough for me.
Definitely happy to own one of the best cars ever [emoji1] I really know what true love feels like now haha
https://www.sau.com.au/forums/topic/469547-newbie/#findComment-7827021
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
