4 x NEW 285/30/18 Advan AO48 medium hard semi slick
I have for sale 4 x NEW 285/30/18 Advan AO48 medium hard tires for sale.
These are a 2008 build however stored correctly so they are fine.
Melbourne pick up only
Will only sell the four together
$1000 ono
https://www.sau.com.au/forums/topic/469549-tyres-clutch-blown-33r-gearbox/
R33 GTR - OS STR TWIN PLATE CLUTCH
I have a used OS STR Twin plate clutch+flywheel.
The OS Giken STR Twin Plate Clutch Kits have been designed for street use while still capable on the race track.
  • Lightweight feel, close to standard OEM clutch feel
Its in excellent condition - has done approx 3000kms only
Selling as I have gone sequential
$1,000 ono
Located in SE Melbourne
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
