E85 gains with vq35de?
Hi everyone,
Just bought my first Stagea a few days ago, a 2005 350rx.
Just wondering if there is anyone here running E85 on the NA VQ engines, and whether there is much gain to be had?
My last car was a turbo mx5 which was running E85, and that saw noticeable gains.
My to-do list of mods will include (but are not limited to):
-plenum spacer
-z-tube intake
-exhaust
(any other easy recommendations are welcome. don't want to go too expensive)
Thanks,
Nic
https://www.sau.com.au/forums/topic/470049-e85-gains-with-vq35de/
Ok well then you could pick up a few KW but given the difficulty of ensuring a constant supply of E85 you would probably want to run a dual fuel set-up which may make the whole project uneconomic.
On an NA motor designed for 95/98 it'd be a bit of a waste as you'd be increasing your fuel consumption and cost (in comparison to running 98) for zero / absolutely minimal benefit from the extra octane. There are a few people around that have done this kind of thing on the turbo models but on a stock NA the drawbacks and cost significantly outweigh any benefit that you could expect.
On the other hand if you are planning on fitting forced induction or going for big compression at some stage it would be a well worthwhile bit of work!
Your list of to do mods doesn't include an ecu or piggyback... So by the time you do that plus flex fuel, it's not going to be a cheap exercise for very little gain.
Do a proper exhaust, use the E85 money for exhaust manifolds (coz they're cool).
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
