Wow!  This is first time I've seen another Scuderia R32 GTR...my brother has 001 and has had it for about 20yrs [emoji4] Do you have any other pics of your car?
I was reading up on your brothers one while looking for information for this one
I don't have any photos of the car however it is a factory TH1 but now painted blue...
Do you know much about theses cars?
There were only 6 Scuderia's sold...super rare :)
Being a low volume import, they were imported and complianced by Scuderia.
my brothers has a Scuderia compliance plate, Scuderia dash cluster and Scuderia boot badge...they were also fitted with the n1 boot and bonnet lip and the front bar snorkels.
  • Like 1
I've read that 3 out of the 6 had been used for racing and the other 3 sold to high profile individuals (Mark Scaife, A porshe cup driver).
My friend and I are trying to work out who originaly owned this one.. Do you who owned your brothers one?
  • Like 1
My brother bought the car off Paul, nice guy. He also runs and owns the wharfs down at Pyrmont.
Where did u hear that Paul was an owner of one of these Scuderia's?
Yes I did hear that Skaife owned another Scuderia as well, via paul.
  • Like 1
Out of curiosity why are these a low volume import? Whats the history behind these particular 6 cars?
From what I can understand I am probably off a little. 6 32s were imported and sold as new with a bunch of goodies, N1 bits and stuff that came on the nissan adm 32s
3 had been sold for race use the other 3 had been sold to high ranking individuals..
001 - Paul Whitmarsh
002 - Mark Scaife (Aparrently)
003 - Unknown
  • Like 1
  • 10 months later...
I'm not entirely sure if he owned 002 or 003 tbh. He may have even owned 1 of the 3 race cars...ill speak to my brother and let u know. He is also on this forum but hasn't logged in years.
Did you end up speaking to your brother?
Number 004 just went up forsale so I'm back to hunting for more info
https://www.lloydsonline.com.au/LotDetails.aspx?smode=0&aid=8121&lid=1356443
i didnt end up talking to my brother about it - i'll ask him to login & he can comment.
dark grey 004 - im not personally keen on the colour & it doesnt have the n1 kit fitted which apparently was stock on the scuderia - may have had the front bar changed hence no snorkels. no rear n1 boot lip as well?
how much do u think it will fetch?
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
