RB20 ECU power info needed
Hey all,
Went to test my ECU was working for my RB20 into S15 swap today and was unable to get consult working.
RX,TX,CLK all have continuity and are correctly pinned in the consult plug. Consult also has 12v and earth.
A little probing revelaed that the ECCS relay is not triggering, i have 12v on both sides of the coil with the ignition off (which is correct as per the nissan r32 servcice manual). I believe the ECU is supposed to switch and earth on pin 16 (ECCS Relay) when it turns on. So lets check if the ECU is turning on.
Pins 50 and 60 (ECU earth) both have a good earth.
Pins 49 and 59 (ECU pwr supply) both have 12v with ignition on
Pin 58 (Battery pwr supply) has 12v battery constant
Pin 45 (Ignition switch) has 12v when ignition is switched on
If all my power and earths are good then the ECU should be turning on? But yet i can't connect via consult and it's not triggering an earth on pin 16 (ECCS Relay) and triggering the relay itself. As my ECU has a NIStune and NIStune flex fuel board fitted so the little LED's have been removed, so unable to tell that way.
Will be checking it all again tomorrow but just after any ideas on why it seems the ECU is not turning itself on.
Thanks
https://www.sau.com.au/forums/topic/470136-rb20-ecu-power-info-needed/
Got a spare ECU? Sounds like everything is working ok so perhaps an ECU fault. Checking against a known working ECU is a quick and easy way to rule this out
Seen as the ignition key should be the trigger for the relay (to earth the ECCS coil side), it should activate it
Also check your fuses. I know my R33 has 2 engine control fuses and one of them (if installed) makes the car stay on even with the key out so maybe something silly like this?
Switched with a known working ECU and still a no go. Did some more investiagatin (using R33 manuals which were a little more clear) and it had pretty much the same troubleshooting info. It did say to check the ignition system (pins 10 and 20) and the injector (pin 107,108 and 116) earth points. The injectors i figured i didn't need those pins earthed as the actual injector signal pins pull to earth to activate the injector. And the ignition system i wasn't going to earth through the ECU as i am using yaris coils and was going to delete the ignitor.
Turns out that they all need to be earthed for the ECU to be fully working. As soon as i connected 10,20,107,108 and 116 it turned on fine and fuel sprayed everywhere in the engine bay as i have the fuel line disconnected and the pump started priming haha.
So for future reference, don't just disregard the nissan manuals (even if they don't make complete sense sometimes)
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
