R34 gtr boost limiter?
Hey guys, so pretty much important myself a bayside blue 2000 r34 GTR, been super keen to get this car for the last couple months waiting, and today was the day to pick it up and drive it home, first 10 minutes car was a dream looked felt amazing just wanted I wanted, then... a problem started so  symptoms are this,
- start the car turbos/boost everything runs great, give it some gas and the turbos spool up to about 1 bar ( which I didn't think was stock boost settings but anyway )
then 5-10 minutes later I will go to just Accelerate normally and it will start to spool but when it gets to around .4 bar it will cut all the boost and the car will act like it has a speed limiter and not getting any air in, after that I had to keep driving the car in a higher gear to make sure it never gets into + boost because it would loss all power and not run, in 6th gear it will spool to around .2-3 bar at about 110 but as soon It gets over that bam cuts out again.
if I turn the car off and back on, problem immediately  goes away and car runs perfect again, then all of a sudden will start up again a couple of minutes later, watching the boost gage on MFD I can see it climbing into + boost then all of a sudden drops fully down ( with no wastegate noise or anything ) and the car staves for air.
any ideas of what it could be would be amazing, it's kinda put a downer on my excitement for getting this car, and really hurts when I still have a 1000km trip home with no boost
https://www.sau.com.au/forums/topic/470406-r34-gtr-boost-limiter/
Bummer, but these old cars need TLC like any other.
If it happens only when the car is warm it could be vac line that expands, could be bad sensor (I once had a bad CAS and an O2 that would only play up warm). AFMs with dry solder joints can also play up when warm if they are only just started to go.
You need to pop the bonnet and get in there for a look. Dos a boost leak test, get a field services manual and multimeter and test some sensors. If you are not comfortable with those basic testing things take the car to a workshop that knows RBs.
Factory ECU? You can buy a consult cable (I think like $100?) and download ECUTalk for free.
  • Like 1
Seem to fix the problem, have driven about 600 more Kms and if hasn't gone into limp mode so that's always good, I pretty much unplug all the easy to get to cables blew them out and plugged the back in, someone I know also thinks that it could be because the car wasn't driven for 7-8 months that it could have build up somewhere and driving has fixed it
cheers heaps for advice and help
time to enjoy the car now
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
