GTR32 Austria
So, im introducing myself one more time and want to share my european nissan with you guys, wish some honest feedback, pro and contras!!
Sebastijan my name and im living in Austria, kinda sucks but yeah :D not the point of this thread !!! 26 years old and still work as an Truck technican/electrican..
Got The R32 since 2 years now and did some new mods, not that big, just a small things!
At the moment;
rb26 stock bottom end
Apexi cams
Haltech ECU
ID1000
Walbro 450l Fuel pump
Radium Engineering FPR, Fuel Filter, Fuelrail,
Gt2871R twin Turbo, (I know not the best choice for the rb26)
Intercooler, intake, exhaust etc. the usual stage one mods
https://www.sau.com.au/forums/topic/470461-gtr32-austria/
Starting to change the turbos and fueling systems, did also a brake upgrade, went with the 4 piston EVO calipers with an adapter made in Finland, nissan 370Z brake discs on the front
355x32mm and on the rear i let it stock Brembo, with an BM57 brake master cylinder
it was hard do pick a fuel rail.. i dind´t want to get a blue or purple one, didn´t want anything that shiney, i decided to get the whole system from Radium Engineering with black Ultra Flow Fitting, didn´t want the blue/red fitting and/or the shiny rail... i dont like to be attacked by the rainbow when you pop the hood :D
made it work with E85 BUT... they abolished that in Austria !! so thats my luck ...
Turbo water /oil  lines are all flex hoses, looks good and it makes delete that old rubber stuff, plus its easier to work with !
  • Like 1
https://www.sau.com.au/forums/topic/470461-gtr32-austria/#findComment-7829952
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
