WTB R32 GTR (in Melbourne)
Have a budget up to $43000,
Looking for something modified,
Prefer it to have been professionally done.
Anything below 130kms on the body, any color, body should be decent (please no rust on chassis).
Clean history, maintenance log, and receipts, would be great.
Contact : Josh : 0403677341, or PM me
https://www.sau.com.au/forums/topic/470820-wtb-r32-gtr-in-melbourne/
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
