Advice / Input
Hey Guys i'm new to the forum and need some help if you don't mind.:banana: I live in South Africa
I currently have an Rb 25 Det lemme give quick run down on spec's.
Sub Assembly skimmed 1 mm Rb 26 pistons 86 mm COMETIC Head Gasket
Head done ported and gas flowed cams cut 270. Done by Steve Clark No Sweat Racing
Head currently has all Rb 26 parts , Valves , Quarters , Retainers , Valve Springs , Lifters etc. So Head is Solid Cams and Lifters. Head can probably rev about 8500rpm+ but oil pump is stock.
Branch build by Marius from Full Boost 3 into 2 into 1.
Turbo Garret 60-1 T4
Bosch 750 cc Injectors
Bosch 044 external and Facet in tank pump
Rb 30 Clutch and Pressure Plate
40 mm Wastegate
Custom Intake Manifold
Intercooler
Spitronics Engine Management 60-2
70 mm Exhaust
Currently has 1 Bar map on 95 ctane pump fuel. Took the car for Dyno but was spark breaking on the Dyno will replace this weekend.
Not sure if any of you have similar set ups. So this is where I need some info please car will be going back to Dyno soon:happy:
I will be Changing Fuel to 50/50 95/Ethanol
What do you guys thinjk Rb 26 pistons can take max boost?
I'm looking to try and push for 1.2-1.5 bar boost is this ok?
What Hp should I aim for safely?
If you guys can assist with any input will be highly appreciated. Sorry about the book tried to give as much info as I can:cool:
Thanks
Brian
  • Like 1
https://www.sau.com.au/forums/topic/470997-advice-input/
Hi thanks man. It is a 1972 Chevrolet 4.1 Limited manufactured in SA and Australia also had them.
Awesome, I'm not a huge muscle car guy so would never have managed to guess. I hope someone here can give you some guidance. :)
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7836682
Thanks and I hope they will assist me. Unfortunately had to do mod in there because they never brought R32,33,34 to SA. We can only buy the engine's here or import the car which is very expensive. I would like to own a R34 Gtr Vspec though:banana::banana:
  • Like 1
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7836684
1.5 bar is nothing - do not go by numbers - your tuner should keep increasing boost until it becomes counter productive and similarly tune to max with regard to exhaust temps knock control etc. You will get what you get.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7837240
Hi Kiwi I've been busy with converting a set of coils but came across another thread discussing some of the issues other guys are having. After reading through It seems to me that I may have a similar problem. So I removed all the coils including the aluminum portion that is bolted in the middle of the cylinder head. Low and behold the hole bottom of the aluminum casing is black seems that the coils have been earthing against it when ever it spark breaks. So my car starts normal idles normal and rev up to limit when stationery also is not missing like a dead plug or coil. Only time it spark breaks it under load. So I got some liquid electrical tape with a brush and also bought some plastidip spray also for electrical insulation. I will be spraying the aluminum cover with that to insulate it so the coils does not spark against it. Also will do the coils and suppressors with the other. Worth the try I guess. I unfortunately cannot have the aluminum portion cnc'd out of plastic as the other guys did. So I will be doing that tonight possibly with put everything back tomorrow and go and test. Hopefully resolves my issue if not I have been busy with a set of other coils. Don't know if you've seen any of the threads speaking about spark break issues.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7838250
Yes there are hundreds of such threads. Your fix may work for a while (gap your plugs down to 0.8mm as well) but start saving for some new coils.
https://www.sau.com.au/forums/topic/470997-advice-input/#findComment-7838265
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
