R33 GTR Vspec -MNP targa car
My targa spec R33 GTR is up for sale. very regretful but don't have the time to do the build I want to do.
as mentioned this a targa Tasmania spec car and was very competitive. Main build was done back in 2007 after import and only saw targa events from then onwards.
Few mods -
DMS Motorsport coilovers. All arms adjustable, Hardrace mainly. Brembos need a paint job but still work a treat, running forza FR6 pads (literally brand new) Could do with new rotors, ATTKD 2 piece from Just jap are my go too.
Enkei RPF1 18x9.5 - 265 RS3 all round
Rotor something 18x9.5 spare set yokohama s drive's - these were a wet or street set
6 point weld in CAMS certified cage with harness bar, will come with CAMS log book. Side intrusion is very easy to get into and out of even for me who is 6'7, interior trim still in but cut to fit cage. Will come with simple bucket seats as I only just purchased the Sparco and it is very bloody hard to get seats that fit my fat ass so not keen to part with it. 5 point harness'
Aftermarket helical cut gearset (not 100% sure what, told ppg) opc clutch. Held a 6-700 hp motor before this motor.
Running Haltech plat pro, Haltech wideband & gauge, Can HUB, 3 bar map sensor, Haltech boost solenoid (18psi) terra trip rally computer and terra trip intercom system, tuned on E85 @ godzilla motorsport (made 300kw)
motor has n1 turbos custom stainless intake piping with pods, 1250cc bosch inj, aeroflow fpr, dual feed rail with stainless braided fuel lines from back to front, AI sp1200 surge tank and holley dominator external pump + walbro 460 lift pump, oil cooler with T'd in Braided line to boot for Moroso Accusump, Split fire coil packs, have a spare set as well. Baffled catch can with breather.
My aim was to put everything in needed to support a big power motor and aside from an extended sump it is pretty much there. Most the hard work is done.
was waiting on extended sump to plumb the catch can drain back to sump. I literally copied this whole setup from another track 33 gtr that ran consistently for 4 years and only met its death due to engine bay fire caused by fuel line split. It is the best setup you can do to save an RB before going to dry sump (arguable statement)
Aircon still in great working order, perfect for sitting in pit lane waiting to go on a bloody hot QLD day.
This car had a monster motor which made up to 700hp but motor spun a bearing so a reconditioned one went in and is about 18,xxx old, Nismo 320km cluster reads 92xxx
Car was registered in Tasmania and has a mod plate for seats. Was about to sort out the mod plate for cage and a few other things but dont have the time to do what I want to do anymore. Would look at swaps for other cars of interest, street cars, 4x4, Track only cars etc.
I am not going to pretend this a concourse condition car it certainly has marks and scratches in places and the sills are not in perfect condition. This was and is a track based car, what I can say is it has been very well looked after over the years in terms of maintenance. Consistent oil, oil filter, fuel filter changes and spark plugs just changed. Always used Penrite 10 tenths 15w 50/60. Have just picked up the new Nulon racing oils 10w-50 and was keen to see how it performs @ $110 for 5L it aint cheap and would stack up over a race season so I am hoping it is an epic new oil.
Price is $36k
Also have a semi enclosed trailer for an extra $5k
Plenty more pics and info just PM if interested.
  • Like 2
https://www.sau.com.au/forums/topic/471029-r33-gtr-vspec-mnp-targa-car/
18 hours ago, Gymkhana said:
Literally saw a picture of this on a GTR Facebook page today with a boat behind it haha, looks amazing.
Yeah Andrew from Motive stole it and posted it haha. I thought it was a fitting picture to get.
  • Like 1
  • 4 weeks later...
Bump,
Calipers completely rebuilt and painted brembo red, it had 2 rooted caliper pistons so have had custom ones made for it. ATTKD 2 piece rotors and Hel braided brake lines also added.
Will potentially have TEIN Circuit masters in next week if this guy will get back to me with freight cost!!
  • 3 weeks later...
TEIN circuit masters acquired. Will be included in sale.
Number plates sold.
Make an offer if you're interested. Have put a deposit on new race car so need this to move
  • 4 weeks later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
