Gday from WA
Gday guys. Not a skyline owner but a fan regardless.
Little intro about me. 34 years old, bit of a nerd. Love Astronomy and 4wding.
My current car is an imacualte Version VI STi
Last year I spent a lot of money on the old girl trying to modernise her performance.
I currently did the following
Engine:
- EJ207 SCD block
- Rehoned and cleaned, remachined.
- ACL Race bearings
- Nitto I beam forged rods
- Weisco forged pistons
- EJ257 nitrated crank (for 2.13L capacity stroker)
- ARP rod bolts and main bolts
- 04 WRX rebuilt heads with shimless oversizded valves
- Kelford 272 camshafts
- OEM Subaru MLS Gaskets
- Kelford springs and retainers
- Lots of head porting
- DW 1000cc injectors and DW billet fuel rails
- ARP 625 aged headstuds
- ARP case bolts
- Vernier cam gears
- 11mm oil pump
- Blouch dominator 1.5XTR ball bearing turbo @ 22psi
- Process west (largest) TMIC
- Process west CAI
- Ultrex UEL headers, double ceramic coated and wrapped
- 3" ultrex up-pipe
- BPM 3" TBE
- Autronic SM4 ECU with antilag and rotational idle
- Ported inlet manifold
- upgraded fuel system with aftermarket regulator and braided lines
- 600HP fuel pump
Driveline
- 04 Long ratio STI six speed
- Thicker/stronger axles
- R180 rear diff
- 600HP organic clutch
Suspension
- Tein coil overs all round
- Pretty much the entire whiteline catalogue of suspension accessories.
I havnt got many performance figures yet but the car did run the following at the motorplex
Elapsed time:         11.628 sec
Terminal speed:     123.55 mph
60':                          1.785 sec
Theres more in it I just need to learn to shift these STI 6 speeds a bit quicker as I find them quite notchy and goofy.
  • Like 2
https://www.sau.com.au/forums/topic/471134-gday-from-wa/
I've always loved the looks of old gen STI and EVO. Nice looking car.
 Since I live in Canada I have no clue what WA is lol, but regardless of that, Welcome aboard!
Edited by drunken0elf
https://www.sau.com.au/forums/topic/471134-gday-from-wa/#findComment-7838586
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
