Workshop near St Kilda for general maintenance/fixes?
Hey guys, tried posting in the workshop thread but I don't think anyone looks there anymore.
After a workshop in/around St Kilda area to do some general maintenance/repairs to my C34 Stag. Got a newborn due in a couple weeks and ran out of time to do it myself, need the car reliable again before she arrives. Needs brake booster replaced (should I get it on ebay first?), fluids done, the usual "I've ignored this crap for way too long and just been having fun" stuff, and a general check-over before trusting it to family duties. Asked a local mechanic down the road and he said he doesn't touch imports. No idea why.
I'm not to keen to drive it too far with brakes spongy, so something close would be awesome. Thanks.
Intermarque Automotive
17 Islington St, Collingwood VIC 3066
Phone(03) 9428 4460
Dixon has been a great help and support with my V36. I don't know if he will look at your Stag or Elgrand however if I had one I would take it to him and the team there.
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
