M35 rough idle / shudder
Hi,
I've recenly had problems with the car and would like to know if it sounds familiar.
Symtoms :
- Rough idle : the car does not stall but you can definitely feel a  shudder
- Shudder also present when driving, especially around 2000-2500 rpm
Coming from the engine 100%, it is less noticeable once the turbo kicks in but there is a slight power loss too.
Problem has increased in intensity when I was driving it home.
If someone could point me in the right direction that would be great.
Mechanical skills close to null, if someone around Sydney is keen to have a look at it, I'd obviously pay for your time, but I can of course try a few things on my end too.
Cheers!
https://www.sau.com.au/forums/topic/471304-m35-rough-idle-shudder/
Hi,
Symtoms :
Cheers!
Contact m35stagea on this forum, he can help scan your car for fault codes.
Ok, will do thanks!
One more thing is that there is no lights on on the dash. No engine light nothing. Not sure if the diag will show something if engine light isn't even coming up :/
1 minute ago, valf said:
Ok, will do thanks!
Not sure but no hurt trying right?
This guy also know a fair bit about M35, or Scotty on this forum as well but since you're in Sydney and m35stagea is also in sydney.
On 22/07/2017 at 5:54 PM, valf said:
Do you have a link for the oem coil packs / spark plugs?
I'll change those and head over to m35stagea's place to give the car a scan.
Thanks for the help!
OEM are like $850. I got my NGK ones from Veales for $600. Spark plugs you can get from Super cheap for $120
  • Like 1
  • 3 weeks later...
Finally received the coil packs yesterday,
Started changing it today, went quite well on the passenger side (remember, I've close to no mechanical experience).
I don't know where to start on the driver side though because the middle coil is hardly accessible.
Can someone tell me how to proceed ?
On the bright side, I've started the car and it runs perfect so I got lucky, the faulty one was one of the first 3 I swapped :)
All done, thanks everyone! Glad I did it myself, will go to bed less stupid than I was when I woke up [emoji4]
Give yourself a pat on the back. Great to see people having a go. DIY is the way to go for most of these minor little odd jobs[emoji106]
  • Like 1
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
