M35 rough idle / shudder
Hi,
I've recenly had problems with the car and would like to know if it sounds familiar.
Symtoms :
- Rough idle : the car does not stall but you can definitely feel a  shudder
- Shudder also present when driving, especially around 2000-2500 rpm
Coming from the engine 100%, it is less noticeable once the turbo kicks in but there is a slight power loss too.
Problem has increased in intensity when I was driving it home.
If someone could point me in the right direction that would be great.
Mechanical skills close to null, if someone around Sydney is keen to have a look at it, I'd obviously pay for your time, but I can of course try a few things on my end too.
Cheers!
https://www.sau.com.au/forums/topic/471304-m35-rough-idle-shudder/
Hi,
Symtoms :
Cheers!
Contact m35stagea on this forum, he can help scan your car for fault codes.
Ok, will do thanks!
One more thing is that there is no lights on on the dash. No engine light nothing. Not sure if the diag will show something if engine light isn't even coming up :/
1 minute ago, valf said:
Ok, will do thanks!
Not sure but no hurt trying right?
This guy also know a fair bit about M35, or Scotty on this forum as well but since you're in Sydney and m35stagea is also in sydney.
On 22/07/2017 at 5:54 PM, valf said:
Do you have a link for the oem coil packs / spark plugs?
I'll change those and head over to m35stagea's place to give the car a scan.
Thanks for the help!
OEM are like $850. I got my NGK ones from Veales for $600. Spark plugs you can get from Super cheap for $120
  • Like 1
  • 3 weeks later...
Finally received the coil packs yesterday,
Started changing it today, went quite well on the passenger side (remember, I've close to no mechanical experience).
I don't know where to start on the driver side though because the middle coil is hardly accessible.
Can someone tell me how to proceed ?
On the bright side, I've started the car and it runs perfect so I got lucky, the faulty one was one of the first 3 I swapped :)
All done, thanks everyone! Glad I did it myself, will go to bed less stupid than I was when I woke up [emoji4]
Give yourself a pat on the back. Great to see people having a go. DIY is the way to go for most of these minor little odd jobs[emoji106]
  • Like 1
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
