Splitfire RB25DET S1/S2 Coil Packs, RB25DET S1/S2 CAS, R34 NEO stuff.
Hello,
Have the following for sale, located in Wollongong NSW (2500):
6x RB25DET Splitfire Coil Packs to suit RB25DET S1/S2 motors. Only reason for sale as went RB25DET NEO and have upgraded ignition. 6-8 months use in perfect condition - $300
Nissan RB25DET S1/S2 CAS, in good working order - $150
R34 NEO Intake Manifold, complete with rail and injectors, IACV, throttle body etc - $150
R34 AC Compressor - $150
R34 Engine Mount brackets - $30
R34 NEO Engine Cover - $50
R33 Turbo Exhaust Manifold, good condition/no cracks/straight/flat - $80
R33 Golpher Racing Radiator - straight/no dings -- old motor did blow head gasket very minimal oil, have cleaned out and bathed the radiator, but probably need a hot flush - $50
Can get pics if needed, but pretty sure everyone knows what it all looks like.
Feel free to PM and I will get back to you if you are interested at anything.
Cheers,
Noobles
Edited by Noobles
Coil packs are different between S1 and S2. The latter has built-in igniters. Which one have you got?
S1/S2 CAS are also different, but unsure of interchangeability.
S2 coil packs with built in igniters... can be used on S1 with S2 loom or modifying existing (I should of stated though).
It is a S2 CAS, but will work on S1 (well I have done this in the past in my experience).
Cheers.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
