Well I have sold the sil80, luckily to my brother so will still be doing all the work on it and be able to drive it every once and a while.
Its been a journey but have now moved focus to 100% race cars and new car is here just needing an engine & gearbox setup to drop in which is all it needs as is an epic base to start with and still a nissan.
Cheers for reading and following along.
  • Like 1
On 5/23/2022 at 7:42 AM, ActionDan said:
You fokin w0t m8
Don't stress too much, I have an epic new s chassis replacing it
On 5/21/2022 at 9:10 AM, Dose Pipe Sutututu said:
Wow!
End of an era, luckily you still have access to it for a steer here and there
yeah it is, whats next is better I think for the efames 😂
  • Like 1
I'm listening....
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
