3 hours ago, ActionDan said:
In that last glory pic, is there a pool of oil under it lol
Also are you tiny or is the driver f**king massive?
Yep, big milkshake under it.
Anthony is a big bloke, driver seat is hard up against the roll hoop.
  • 3 weeks later...
Well spent a bit of time this week going over the 180sx in preparation for hill climb tomorrow. Compression test came back 115-120 across all 4, the blow by had filled half the compressor housing and Intercooler with oil so pulled it apart gave it all a good clean.
Dropped the oil and there was no shiney bits so fresh 20-60 oil went in with a new filter. Still blew a little bit of smoke on quick test drive so see how it goes tomorrow and may give it a bit more boost.
Hopefully holds together for a few runs.
1 hour ago, ActionDan said:
Cold and dry?
warm.
Ended up 5th outright with a 1.01:89 at the hill climb but only did 3 runs as blow by got worse. Thats a new pb too so will be alot quicker with a healthy motor
It was blowing oil up the boost solenoid ref line and out the port.
Tried venting catch can to atmosphere which helped a little bit but still pushing oil to catch can. On the last run turned it up to 22psi but blew off intercooler pipe on gear shift after launch so called it a day.
Pulling engine this week as couldn't find another one locally.
The only way a vent will help is if you vent the sump and the head separately like I did on mine.
You need to equalise the pressure top and bottom.
Will be doing whole new catch can/breather setup when I get this motor freshened up. Atp 2l can and all dash 10 lines.
Priced up everything for forged bottom end through golebeys so once engine is out and everything measured up will place the order.
34 minutes ago, ActionDan said:
Even with a fresh motor, Nissans need bulk breathing capability.
Vent it top and bottom and happy days.
2x - 10 off the top, 1x - 10off the sump and the factory block fitting should be hopefully help. Never had issues with the s14 but the rocker cover is a better design.
Progress back moving under its own power.
Been spending a little bit of time sorting out the power steering setup since I didn't end up going electric. Went with an aeroflow tank as I stuffed up the original one trying to weld on dash fittings.
Cut off the old bracket and made a template, copy to aluminium, cut/drilled and folded.
Finished making lines and filled with fluid only to find I had hoses the wrong way on the rack. Switched them around, Bled it up and everything thing was all good.
Also fixed cooling set up by moving one of the fans, got a new nismo thermostat just incase as the old one was around 11 years old. New coolant with demineralised water and now temps around 80c at idle.
Still sorting idle with ethrottle as when I stab the throttle it doesn't return to idle smoothly or stalls so will keep adjusting the proportion and stall gain to make it right. List of things needed to get back on the road is getting smaller.
  • Like 2
That won’t be helped by adjusting the throttle pid settings, it will be your base throttle table referenced before closed loop takes over.
  • Like 1
Thanks for the info will have a look at that before I do anything else.
Just spent a bit of time this morning doing a few small things like fitting indicators, rear speaks, shortening intake pipe and cooling plates.
Engine bay all done just need to fit a washer bottle in the corner
Thanks to @Ben C34 advice went back and checked the ethrottle setup and set it up properly so idle is smooth at 800rpm and doesn't stall ?
Big ticket items left is driver side lca, cat back exhaust and Coilovers.
  • Like 1
1 hour ago, iruvyouskyrine said:
how much were the brand new indicators
Cheaper than r33 xenon lights ?
Were around $500 ?
Almost looks like it came from factory with all the "standard" Nissan parts.
  • Like 4
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
