Got the new trailer last week, worth every cent. Car can be loaded without removing the front bar and airing out the air bag is cool. Now just need to upgrade the tow car.
Swapped the 4.36 ratio diff into the race car so can now put the gtr diff back in the sil80.
Top shafts are gtr, bottom standard gtst. Might drain the 98 and start E85  tune on the race car.
  • Like 1
  • 1 month later...
Got stuck into the HQ last week and fitted up the msd unit and dizzy. Should have done this year's ago has made the car enjoyable. Will fit extractors and twin 2.5 exhaust when I get back from next shift at work and start tuning the carb so it's not so rich.
And started new job in Brisbane. Finally got to do a back to back Dyno of standard plenum VS short runner intake on a standardish Rb25 (kinagowa td06, e85, 25psi, greddy fmic, 3 inch exhaust, link g4 plugin) big hit to mid range power. IMG_20191210_110548.thumb.jpg.0992b12b5b24dc9dfd1ed6f4e5c3daad.jpg
  • Like 1
Nitrous almost all setup on the HQ
Image may contain: people sitting
Race car now lives in Brisbane, been drifting the 180sx heaps. Bent steering stuff last week so need new lca & tie rod at minimum and new mirror & door handle after clipping a barrier.
Sil80 hasn't been touched
  • Like 2
  • 3 weeks later...
A late night update
HQ got 4 into 1 extractors and twin 2.5 inch exhaust, finding someone to fill nitrous bottle is turning out to be difficult.
Went to Airlie Beach, rented airbnb
Finally changed oil on drift car. Went to archerfield and had a great time, cars a little worse off but driving has improved
Actually made small progress on the sil80 and started stripping brake calipers for powder coating and new seals
  • Like 1
Nice.
Wouldn't a local BOC or SupaGas fill it for you? If not then find the local performance workshop/engine reconditioners and see if they know?
Any clips of you banging in to shit you dirty drifter?
BOC don't do nos system, just the industrial stuff and the one that does only does it a week before a big drag meet in Cairns or Mackay, should have just LS it.
Got some in car stuff, will go through it when I get home as still in Brisbane for work.
  • 1 month later...
Drove QR Autumn Matsuri last weekend. Heaps of fun and driving with mates that made the trip from Townsville.
87715630_137210494451420_7867413834594516992_o.thumb.jpg.e02d2bfa46440bdc5ad398b2f6c65e37.jpg
IMG_20200309_165023.jpg.1e6384c7fe4ada4eccbfd80f5106de62.jpg87263200_2722848831281005_4335733703939457024_o.jpg.80d71864f8b37cad102aaf751106dec7.jpg
Blew a welsh plug out of the block Saturday night IMG_20200308_073705.thumb.jpg.1b26c81e57704497f1839dab50768b5c.jpg
Got a new one and got it in and drove until the last 1.5hrs when 3rd gear decided to finally explode. Got a video from in car that I need to edit.
Did post event comp test and tested 150-155psi, tested cooling system too and all good. New s14 gearbox was sourced and inspected before install, all new filters and fluids all ready for Thursday night at Archerfield drift. Definitely need to go e85 as extra 20kw would help on the big tracks. Once I get home hopefully do a few more steering mods and fix a few chassis problems.
  • Like 2
22 minutes ago, Dose Pipe Sutututu said:
Boom boom with the box!
How did the pads go?
They go pretty good but bloody noisy. Haven't done any really big stops(over 160kph) yet. Will go the performance street ones next.
You'll get sparks too with big stops ?
  • Like 1
Just now, ActionDan said:
Is the video cool?
Happy you're out driving, makes me miss it, in the meantime I cut wood and build sheds (and ruin my elbows!).
Video added.
Need to find something simple to get out there and have fun in- 350z/v35 would be my pick atm
How big the new shed?
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
