Got some parts I need to move on:
*rb26 crank angle sensor only 2000kms old - $150
*r32 gtr center triple gauges - good working condition, no facial cover but can supply a brand new one - $150
*r32 gtr genuine used N1 windscreen washer bottle (only single wiper motor for front windscreen non for rear as it's an N1 item) wiper motor doesn't work - $100
*brand new innovate LC-2 wideband in the box, minus sensor (can be bought easily enough through eBay or rocket industries) - $150
*rb26 L19 headstuds, used and torqued once, come with necessary nuts and washers - $500
all items in Sydney
happy to post at buyers cost
will try add pics in the next few days
https://www.sau.com.au/forums/topic/472456-gtr-parts-others/
Selling my catch can which was made by hypertune (pretty certain I have the invoice from when previous owner had it made)
suits r32 Gtr with front facing plenum like hypertune, plazmaman etc
-12an fittings
-10an drain or return to sump
baffled
painted black
$180 located sydney
can post
