Everything removed from R33 GTR for upgrades
Most parts should fit R32/R33/R34 GTR
-HKS Front pipe, stainless steel, has dent/scrapes but works fine $400
-HKS Dump pipes x2, stainless steel $300
-OEM manifolds x2 $150
-OEM heat shields x2 $40
-Turbo support brackets $20
-Turbo hard lines (water/oil feed, oil return) $30
-Garrett GT2560R -5 Turbo with HKS actuator  (normal shaft play)  $550
-R33 GTR custom oil catch can w/washer reservoir and hoses
Can be plumbed back or vented. $350
-Full HKS hard pipe intake kit (excluding MAFs) $500
-R33 GTR Vspec ALSD diff and shafts $500
-RB26 OEM MAF x2 $100
-R33 GTR OEM Fan $50
-R33 GTR OEM radiator $120
-R33 GTR Clutch line $20
-SARD 700cc Injectors $300
-Apexi Power FC for R32/R33 GTR(no controller) $400
Pickup from Lilydale 3140
https://www.sau.com.au/forums/topic/472468-r33-and-other-gtr-parts/
  • 3 weeks later...
Whats left:
- 1x Garrett GT2560R -5 Turbo with HKS actuator  (normal shaft play)  $550
  • 1 month later...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
