Hey guys so yesterday i tried to do a power slide, and kick the back end out. however my back wheels lost traction and it felt like the front wheel saved me. I've been told i need to make a switch to cut off the "bosch" control, which makes the car rwd? If i turn just the VDC off will i be able to kick the back end out a little or do i need to cut/make a switch for the bosch cable?
Cheers
https://www.sau.com.au/forums/topic/472575-vdc/
They are RWD anyway.  I have heard rumours that the VDC off only partially disables VDC, and holding it down for 10sec will turn it off fully.  I have never tested this though.
I suggest you find a suitable location to test it (private property or race track), and give it a try.
Disconnecting the yaw sensor may work too, but it will also throw plenty of warning lights.
https://www.sau.com.au/forums/topic/472575-vdc/#findComment-7857397
Yeah your car will keep trying to save your life.
holding for VDC for 10 sec will turn it off so you can do cool skids. But if the car notices no loss of traction after about 30sec of turn it off some of the life saving computer power will come back on.
So hold for 10sec (VDC turns off), Do a cool skid within 30sec and it will stay off
P.S the 30sec is a guess on how long
https://www.sau.com.au/forums/topic/472575-vdc/#findComment-7857739
    • Hi guys, I was in Sydney and encountered an aggressive, sadistic Uber driver which I was the passenger. Should I report him and does uber acutally do anything if I report, I know that Uber mentions that they take dangerous driving seriously etc.... What happened in the car First got into the car, thought nothing of it at first when he honked at an illegally double-parked car blocking traffic. But then, as the ride progressed I noticed that he aggressively honked and tailgated at slower cars despite them being close to the speed limit. Final straw was that he went to harass a Camry and honked at him almost every time the camry slowed down, even leaned on the horn while he was waiting for pedestrians to cross before he was allowed to turn left. Also continously honked and flashed lights while camry was parallel parking. What would you do in the situation as an Uber passenger?   Thanks
    • We can use that against you later.
    • And not one multimeter was frightened in the process!
    • Figured it out. Very suprisingly, both headlight bulbs went out and the rear one went out as well. Which is weird because the rear one didn't look broken. I decided to swap bulbs jsut incase and it was infact broken lol
    • Let's keep this little secret between ourselves
