Hey everyone,
So 2 of the rims that came on my car when i brought it have now cracked in the same spot, so figured i may as well buy all new wheels. i've spent a couple hours last night searching the wheels and offset thread, found alot of good information but couldn't find enough to get a proper answer.
I am looking at getting some Rota P1R wheels. having some trouble making sure i've got the right offsets tho.
The choices are the following
18x9.5 +27
18x9.5 +35
18x9.5 +38
Have compared my current to the the following on WillTheyFit.com, but still not sure which would be the best choice, i think the +27 on the front would stick out to much but not sure if the +35 would be to close on the inner.  But i think the +27 would fit the rear pretty nice, Going to jack the car up this afternoon and try and check clearance.
Just wondering if anyone knows off the top of their heads the best offsets to get?
Cheers in advance.
Hey mate.
They're basically perfect, as I have 9.5 and +27 all round. You WILL need to roll/lip the guards if you want to run chunky tyres. I run 265's all round and I do not get scrub and I mean that will barely fit.
The 9.5 +38/+35 will hit at the front. Need a spacer.
IMO, the +27 at the rear pokes more than the front does, I was suprised that when putting same wheel size on all 4 the fronts natrually are a little more in.
I want a 10+38 on the rear so I can run a 285/295 for max tyre.
So ultimately, you may need a spacer or two if you go for the +35/38 combination, the 27 will max it out. 35 with some spacers/extended studs will get it to sit in a little.
Awesome, exactly what i was looking for, i was a bit worried about the front inside hitting the suspension arms but seems it will be okay :)
i will be running 245/40/18 on the front and 265/35/18 on the rear.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
