On 04/12/2017 at 8:06 AM, bcozican said:
Something to consider for the non W.A guys ... while dyno's are dyno's and numbers are number etc etc
the C - Red dyno is notorious for being the lowest reading roller over here.
Even mark said that if i was to go onto another dyno any where else I would see over 400 easily at the wheels.
I'll wait for a dyno day and give it a try.
Anyway its been a week since getting it back and its still hard to get used to the way it comes on boost.
Any chance of a we video ? Or how savage is it. How does it grip and what’s your setup on that front
  • Like 1
Hi,
I'm thinking about getting the same setup!
My exhaust manifold has cracked so I need to replace it.
I'm thinking to get a low-mount so I don't need to change too much.
At what RPM does it makes boost?
edit: The name confuses me, is it a GTX or not?
Edited by FreKev
  • 6 months later...
  • 11 months later...
On 05/07/2018 at 1:50 PM, Shoey84 said:
Hey man, can you confirm how much psi the turbo is running at?
did you need the 10mm spacer to put it on the stock manifold?
I have a hks 2835 Kai internally gated and making 300kw on 19 pounds, (e85) wondering if I can get a bigger  spring actuator to hold around 22 pounds or if I bite the bullet and upgrade to this instead.
im also running a Pfc but gonna upgrade to a link with flex tune as the pfc boost controller is letting me down.
1170cc injectors on the stock fuel rail. Any reason you went forward facing plenum and fuel rail upgrade?
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
