hello guys and seasons greetings, here is where I'm at, I cant seem to post photos, using my cell on this app. I finally got all my parts from RHDJapan. I got a 0S88 a new clutch and cross member. I'm wondering if my clutch fork and release bearing from my old r32 box will work as it's the only thing that's missing,
new I got a new r33 gear box but it came as a pull type setup and I'll be using this in a r32 so this won't work as all my clutch kits are all push types. I do notice some spot for some bolts on the opposite side for a push slave that I can tap, but the next issue will be the part of the box that the release bearing slides. this part is with a pin that holds the fork (pull) can I use the one from my push standard r32 box? this will allow me to use the r32 push type fork and ball type bolt the fork floats on.
I also would like to know if I would need anything else I'll need to use for this os 5 speed gear set. this is a new late r33 box, and all I see so far not opening up the box so far is this for issue.
I would post photos if the forum would allow me. but it's not.[emoji24]
https://www.sau.com.au/forums/topic/472961-new-standard-box-with-os-gear-set/
Dont know about the os88 but push/pull conversions have been done before. Youll need a push setup being, front cover for gearbox, fork, pin, release bearing. The pull type box has the bossess on the outside if the box to mount the pull type slave. You can easily thread the opposite side for a push setup
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
